rear cab mount ?
Just saw these http://*******************/-63-87-ful...hassis-mount-3 and wondering if they will work on my 66 c20. It had the old s brackets with the rubber in the middle before. If they wont work.. any ideas on where to find some is much appreciated.
Build Thread 66 custom cab lwb http://67-72chevytrucks.com/vboard/s...d.php?t=465726 ![]() 66 fleet lwb- In process 64 k10 10inch lift 38.5's- In process 92k1500 400hp on 38.5-parts truck now 8( |
#2 | |
60-66 Nut
Re: rear cab mount ?
Those won't work. The '67-'72 mounts are slightly different than the '63-'66's.
You can get your original ones rebuilt from Steel Rubber. A former member here, Tony Smith makes repro's for the '63-'66's, but I'm not sure how to get in touch with him. Quote:
id rather go with the solid mounts. guess im in for a fab job. oh well
Thanks capt
Never Ending Projects
Not sure if you are referencing those mounts that you posted or some home grown solid mounts but the ones in the link you posted still use a rubber bushing between the cab and mount. These do not bolt directly to the cab.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
![]() Join Date: Aug 2004
there is probably someone on the forum that has these on a parts truck that you could get. put in the WTB and or the parts WTB section
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Oh no im talking about the c20 custom camper mounts with the rubber that runs vertical. They suck and r expensive to repair. Im looking for the style that has a rubber cab mount like the ones above.
Thanks Clyde, Ill give that a shot.
Just an fyi, if you get the c10 rear cab mounts and brackets, they'll bolt right on.....surely someone has an extra set of frame brackets you could pick up....
I discovered this on my truck, which started as a c20 and I robbed some rear cab frame brackets off of a '65 truck bed trailer I picked up....hardest part is getting the rivets off, all the holes are in the same location ![]()
Pro Touring 1964 C10-Under Construction ![]() Project '65 Short Step Daily Driver http://67-72chevytrucks.com/vboard/s...d.php?t=661948 |
yeah those rivets are definitely well set. Thanks for the info. I'll look around before building a set.
I bought a set for my c20 from Tony, they were well made and fit great. He can be found over on Stovebolt.com.
OR his new website on facebook 4-5-6 chevy trucks
Out of curiosity, what happened to Tony? I've bought a few parts from him and benefited from some of his posts.
http://67-72chevytrucks.com/vboard/s...54#post3194654 |
I'm not sure, but I believe banned/suspended sometime within the last year or so?
1961 crewcab
here is a set on ebay:http://cgi.ebay.com/ebaymotors/1965-...item2c5eee052d
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
#15 |
i could check my 60 parts burb, they might be good
#16 |
I also bought new rubber mounts from classic parts:
http://www.classicparts.com/prodinfo...141&variation=
