Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 08-21-2011, 04:39 PM   #1
rocking chevy
rocking chevy's Avatar
1997 gmc sas and other stuff.
Ok so I finally started on my pickup, actually the sas is almost done. I would have posted pictures awhile ago but I didn't have my computer.
Here it is when I got it. Except for the primer spots, It had a couple of dents that I got fixed.
Then I put a two inch block in it, cranked the torsion bars, and got some different rims and tires really cheap.
Then the work begins.10 bolt out.
14 bolt in, and changing gears. I added a leaf in the rear, and put in a five and a half inch block.
IFS crap out.
We got a sas kit from off road direct. Front spring hanger in.
Rear spring mounts, and springs in.
Dual shock hoops.
Front axle. dana 60.
Then replaced everything on the front axle.
Front axle in and shocks on.
I put a two inch spacer on the rear and a half inch on the front. Which made the rear 72 inches wide, and the front 71 and a half. so the front is only a half inch narrower.
Heres what it looks like now. with 35 inch tall tires, and 16 inch rims.
I also found a tonneau cover for only 80 dollars, heres the best pic I have of it.
Heres it parked beside my jeep, which also has 35 inch tall tires on it, there about the same height.
rocking chevy is offline   Reply With Quote
Old 08-22-2011, 10:37 PM   #2
rchavez101
rchavez101's Avatar
Re: 1997 gmc sas and other stuff.
It looks awesome. Great find on the bed cover.
94 Chevy SWB in progress.
http://67-72chevytrucks.com/vboard/s...d.php?t=477390
rchavez101 is offline   Reply With Quote
Old 08-23-2011, 08:21 AM   #3
rocking chevy
thanks
Old 08-23-2011, 10:46 AM   #4
chris@bigjranch.com
KIDHLR
chris@bigjranch.com's Avatar
Very Nice
Christopher Johnson
Project - Grafted In AKA the "KIDHLR"
Conversion - KIDHLR Meets LPG
KIDHLR 2.0 Rise of the diesel(a 6.5 powered 6 Door pickup)
Romans 11:17-22
"Branches were broken off so that I could be grafted in"
chris@bigjranch.com is offline   Reply With Quote
Old 08-23-2011, 04:58 PM   #5
rocking chevy
Originally Posted by chris@bigjranch.com View Post
Very Nice
Thanks, I like your pickup to, or is it a suburban, ha its both!
Old 08-31-2011, 07:14 PM   #6
chris@bigjranch.com
KIDHLR
Uh, yes Officer it's a suburban with a little modification
Christopher Johnson
Romans 11:17-22
Old 08-31-2011, 08:42 PM   #7
rocking chevy
ha nice
Old 08-30-2011, 09:28 PM   #8
rocking chevy
ok so I got the exhaust done, and some other stuff, ill get pics up some time in the next couple of days.
Old 09-02-2011, 09:13 PM   #9
benoit454
Chris
benoit454's Avatar
nice work, what kind of other work was involved in the front axle as far as brakes, wheels, steering, trans crossmember work etc.?
I always see guys do SAS conversion but never see what parts they use or need and what they have to fab or mod to make brakes and steering work or wheels.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 09-04-2011, 10:40 PM   #10
rocking chevy
I actually switched the balljoint axle out for a kingpin last weekend, so when I get new pics up Ill be able to answer your question better.
Old 09-05-2011, 01:37 PM   #11
rocking chevy
I took the ball joint axle out.
heres the kingpin axle
got it in, and I still need to put new lockouts, barings in the pinion, steering stabilizers on, and I think I'm going to put a track bar on also.
I also put another inch in the rear, here it is
then the tires weren't balanced right so I put my jeeps 35 inch mud tires on it and it drives fine so ill get mine rebalanced and put them on sometime.
I also had the exhaust done
and benoit454 heres some stuff I had to do to get things to work. I had to take a notch out of the steering arm so it wouldn't hit the shock mounts.
then I had to flip one of the cross members over so it wouldn't hit the rear drive shaft.
Old 09-05-2011, 01:39 PM   #12
rocking chevy
I also picked up a tahoe for $150 that has paintable bumpers, and the front one has fog lights, and it has inside window parts that I need for my other project.
Old 09-05-2011, 03:23 PM   #13
benoit454
Chris
benoit454's Avatar
nice work so it's all basically stock parts? what did your front axle come from?
Chris
GIT R DONE!!!!!!
Old 09-05-2011, 03:46 PM   #14
rocking chevy
yea its pretty much all stock from some vehicle, the leaf springs are 2.5 inch lift springs from skyjacker for a 73-87 chevy pickup. the axle is from a 91 f350 ford.
Old 09-05-2011, 07:19 PM   #15
benoit454
Chris
benoit454's Avatar
awesome and all the steering and brakes is from the same truck and hooked up to yours without haveing to buy anything else?
I can handle buying some of the bracket kits to hang the springs, but when it comes to the brakes and steering etc. I get lost.
Chris
GIT R DONE!!!!!!
Old 09-05-2011, 08:39 PM   #16
rocking chevy
I bought a new pitman arm(attaches to the steering gearbox), and the high steering arm(the thing I took a notch out of). Then you can buy a drag link, but I just made mine( if your good at making things then you could also, otherwise theirs might work). You can get everything at offroaddirect.com, but if I were you Id only buy the shock hoops and shock mounts that go on the axle, but Id make the spring mounts, because I had to redrill the holes to mount it and you can't put the tow hooks back on with theirs.
Old 10-04-2011, 05:49 PM   #17
rocking chevy
I put paintable bumpers on.
Old 10-04-2011, 09:33 PM   #18
86454k30
86454k30's Avatar
What size lift spring is in the front, 2" or 4"?
86454k30 is offline   Reply With Quote
Old 10-05-2011, 08:49 AM   #19
rocking chevy
2.5 inch soft ride springs in the front.
Old 10-19-2011, 10:16 PM   #20
Dub_X
Professional Crow Bar Tosser
Dub_X's Avatar
My god, that truck is gorgeous. And so much work put into it to make it that way.
Dub_X is offline   Reply With Quote
Old 10-19-2011, 10:45 PM   #21
rocking chevy
Thanks, I still have to put the steering stabilizers on the axle, put my stereo in(and switch my dash at the same time since its cracked), and paint it, then its finished.
Old 11-01-2011, 02:13 PM   #22
modblacksmith
modblacksmith's Avatar
Good lookin truck man, I'm getting ready to do a sas swap on my roommates 97 Chevy using the Sky Off Road kit.
Professional hot glue and pop cycle stick engineer.
72 K/20 soon to be C/10, 454, Th400, 9” rear.
01 GMC 2500HD 8.1, Allison, daily/towpig gas guzzler.
78 Bahner 19’ jet boat, 460 Furd turd.
modblacksmith is offline   Reply With Quote
Old 11-01-2011, 02:42 PM   #23
modblacksmith
Old 11-03-2011, 07:18 PM   #24
rocking chevy
cool dude, should turn out great.
Old 11-29-2011, 10:41 PM   #25
rocking chevy
I got the front windows tinted 20% to match the rear.
I also took the tonneau cover off and put in a chest tool box. I liked how the tonneau cover looked, but I couldn't haul anything taller than the bed so it kinda was an inconvenience.
I used two 2 and a half inch aluminum square tubing and put it between the box and the bed on each side then ran two bolts through the box to the bed.
I also put in four tie downs in the bed, one in each rear corner, and one at the front of each wheel well. I padlocked a chain to one, then ran it through my spare tires rim, then padlocked it to the one in the opposite corner. Its only temporary until I make a holder inside the bed.
