08-21-2011, 05:03 PM | #1 |
big block 64
anybody running a big block in a 64 - 66 have a whole lot of questions
08-21-2011, 06:08 PM | #2 |
Re: big block 64
Here is mine http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Do a search, there are alot more.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
08-21-2011, 08:20 PM | #3 |
Re: big block 64
I had one in my last 66. The 65 I have now is small block. What do you need to know?
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
08-21-2011, 08:37 PM | #4 |
Re: big block 64
when motor was installed had to move it forward, i installed a march serpentine system which uses the long water pump, now i have very little clearance between the pulley and the radiator. I'm running a pusher fan, which is keeping it cool but my problem is i wont to install an air conditioner an there is no room for the fna on the engine side
08-22-2011, 12:31 AM | #5 | |
60-66 Nut
Re: big block 64
You need the short pump for the big block. March makes pulleys and brackets for the short pump BBC as well. I'm running a short pump on the 454 in my '66 Suburban with 2 puller efans.
08-22-2011, 07:51 AM | #6 |
Re: big block 64
I have the complete Vintage Air set up coming for my 65 BB. I understand this will work in our trucks with no clearance issues. Ill take pics once I get this mounted if it helps. MB
08-22-2011, 09:55 PM | #7 |
Re: big block 64
i guess im giong to try mounting the condensor coil with its own seperate fan in a differant location
