08-21-2011, 08:54 PM | #1 |
People know me
th400 help
Just got done installing a th400 into a buddys truck. It was a fresh rebuild from the tranny shop, We picked it up new convertor and all.
Pulled his old th400 out and installed the new, Filled up the convertor with around 3/4 of a gallon of atf and installed, did not stack the pump or anything. Filled up with I think around 13 quarts total and is where it needs to be on the dipstick. In let it run for about 15min and ran it through all the gears. It feels like it puts a slight load on the motor in reverse and D1, when running and putting it back in park it grinds really bad on the park pawl. Gonna take it to the tranny shop tomorrow evening after I get off work. Just wondering what the hell?
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels |
08-22-2011, 12:22 AM | #2 |
Re: th400 help
This may be a dumb question but do you have the vehicle on jack stands and when youre putting it back into park the driveshaft is still spinning?
08-22-2011, 04:52 PM | #3 |
its all about the +6 inches
Re: th400 help
is the driveshaft even installed?
If it isn't installed, then you are doing the same as popping it in park at 5 MPH or so. |
