08-22-2011, 09:30 PM | #1 |
Help! Rear Axle info needed....
I have a 63, and as far as I can tell, it is stock. I want to put in a posi.
SO the questions- What spline are the factory axles? Will a modern 12-bolt posi unit fit? I noticed the shape of the pumkin is a bit different. Thanks!
1967 Camaro - Current Project 1963 C10 - Shop Truck (Next Project) 2008 Saturn Sky Redline - Wife's ride 1993 GMC Typhoon - Getaway truck! |
08-22-2011, 11:04 PM | #2 |
Re: Help! Rear Axle info needed....
Are you sure its not a 10 bolt rear end in it? I have a 64 c20 and its got a stock 10 bolt rear end with an 8 lug pattern
08-22-2011, 11:14 PM | #3 |
60-66 Nut
The '63 & '64 12 bolt truck rear differentials have 17 spline axles. So the '65 and newer posi units will not work in your differential without changing axles also.
08-23-2011, 08:11 AM | #4 |
Thanks for the info. Though it is unfortunate as I was looking to do a quick swap!
10-05-2011, 03:22 PM | #5 |
Not looking to hijack this thread but a quick search for the word "spline" led me here, and you seem to be the best person to ask about this. Would a 67-72, 5-lug axel fit my 66 with stock rear end?
1966 Step C10 |
10-06-2011, 01:36 AM | #6 |
60-66 Nut
As long as your '66 has the trailing arms, and the donor does as well, then yes it will be a direct bolt in. However, be aware that the '71-'87 5 lug differentials are 1.5" wider than the differential currently in your '66. This may or may not be an issue, depending on your tire and wheel size.
