Old 08-23-2011, 01:39 AM   #1
rcbildr
rcbildr's Avatar
Angry Doing engine swap number 3
Just venting some frustration here. Over the weekend the engine in my burb gave me the signs that it's time to be replaced. Over the last 2 months or so it was burning oil pretty bad...close to 5 quarts in 2 weeks...and it was losing power. Saturday I took my daughter fishing and when we get in to town I notice smoke is coming out from under the hood. So I pull in to a parking lot to check things out and smoke is coming out the fill port for the oil and the oil dipstick tube. The burb gets us to the lake and back ok but when we were going up hills it sure left a nice trail of smoke. I was hoping this engine would last until tax return time next year because I was wanting to buy a millitary surplus 6.5 turbo diesel. Fortunately, I have 2 other 6.2L engines to choose from, one is in my shortbed and the other is sitting in my shop. I'm hoping to use the one in my shop but I remember the PO told me he thinks it either has a cracked block or a bad freeze plug...I'll be checking that tomorrow.
On a side note my daughter and I had fun fishing we didn't catch anything big enough to eat but she did catch a couple small bass and I caught a blue gill.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 08-23-2011, 03:11 PM   #2
Dave C
Dave C's Avatar
Re: Doing engine swap number 3
sorry to hear about your troubles. thats a lot of oil!!!
bagged 1989 burb regency conversion
Dave C is offline   Reply With Quote
Old 08-23-2011, 04:58 PM   #3
68Timber
I know the pieces fit
68Timber's Avatar
Hate you can't do the 6.5 swap, that would be sweet.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 08-23-2011, 05:46 PM   #4
jblaven
Ouch, 3rd swap. How many miles on it?
jblaven is offline   Reply With Quote
Old 08-23-2011, 07:48 PM   #5
rcbildr
rcbildr's Avatar
Yeah that engine was showing signs of death for a while but I was hoping it would last longer. I don't know how many miles, that particular engine was a craigslist find.
Had another setback today. The engine I have in my shop does indeed have a cracked block....you can see it right above the freeze plugs on the passenger side...it's about 8 inches long. Oh well looks like my shortbed is becoming a donor truck for now...it's been parked because the trans needs to be rebuilt.
I'm still going to do a 6.5L turbo swap but now it will probably be done to my shortbed....we'll have to see when the time comes.
My Projects:
1978 Camaro Z28
Old 08-23-2011, 08:48 PM   #6
68Timber
68Timber's Avatar
Hate to hear about the cracked block.
John
74 Honda Z50 build
Old 08-24-2011, 03:33 AM   #7
rcbildr
rcbildr's Avatar
Another J code engine bites the dust...that's 2 that I've come across with cracked blocks. The engine I first pulled out of my burb had a cracked block too pretty much in the same area.
My Projects:
1978 Camaro Z28
Old 08-24-2011, 11:25 AM   #8
68Timber
68Timber's Avatar
The engine in the stepside has a cracked block too?
John
74 Honda Z50 build
Old 08-24-2011, 01:09 PM   #9
Edahall
There is hardly any performance advantage of the 6.5L over the 6.2L so don't feel bad. They both have the same stroke but the 6.5L has a slightly larger bore. The 6.2's also seem to last longer than the 6.5's. If you want more power, install headers and a good exhaust on the 6.2 or install a Banks Turbo. Asking for more power (over 200 hp) is asking for trouble on these engines.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 08-25-2011, 11:40 PM   #10
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Damn that sucks hope this other engine lasts longer then the other ones. Glad to hear that you made it back to town at least!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 08-30-2011, 07:11 PM   #11
thirdstreettito
Resident of Here
thirdstreettito's Avatar
That sucks man.
If you arent a member, join The Diesel Place forum, tons of 6.2/6.5 knowledge.
http://www.dieselplace.com/forum/index.php
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
