Old 08-25-2011, 09:48 PM   #1
longblue72
Active Member
power steering geerbox
So its leaking out of the top end of it, would that be the upper input shaft that needs replaced?
Thanks guys
longblue72 is offline   Reply With Quote
Old 08-26-2011, 01:48 PM   #2
425HP409
425hp409
425HP409's Avatar
Re: power steering geerbox
If it is leaking where the steering shaft goes into it, that is called the "sector shaft seal"
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 08-26-2011, 01:54 PM   #3
webfoot
Mine looks like it leaks out of all of it.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 08-26-2011, 05:58 PM   #4
longblue72
Active Member
sector shaft seal ok i got it! thanks
webfoot im telling you once i get my truck looking pretty decent it wants to start leaking different places!
Old 08-26-2011, 07:40 PM   #5
stsalvage
Scrapper 1
stsalvage's Avatar
if your have the factory gear box don't let go of it the auto parts store will sell you a less turning steering gear box have your rebuilt lot cheaper
stsalvage is offline   Reply With Quote
Old 08-26-2011, 07:45 PM   #6
webfoot
How much does it cost to get them rebuild? Are they very difficult to do it yourself?
-me
Old 09-30-2011, 01:52 PM   #7
tnoftsger
Wow, that question killed the discussion, didn't it.
I too would be interested in how to rebuild. I had been warned about the replacement stuff having a different ratio, so i would just as soon rebuild mine, but i'm a power steering gear box rookie, at best.
tnoftsger is offline   Reply With Quote
Old 09-30-2011, 02:13 PM   #8
Wrenchbender Ret
The shaft that the pitman arm hooks to is called the sector shaft. The shaft that the steeing column hooks to is called the worm shaft. The seals are not hard to replace but a complete o-haul could be difficult.
Wrenchbender Ret is offline   Reply With Quote
Old 09-30-2011, 05:43 PM   #9
dfwright
dfwright's Avatar
If you google "Saginaw Box Rebuild - How To" there's an excellent how to you'll find on pirate 4x4
Also, look up "Saginaw Steering Box Rebuild - Smooth Steering" by four wheeler magazine for another good write-up. You should be able to get an idea whether it's something you want to tackle or not.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 09-30-2011, 07:18 PM   #10
71sierragrande
Petroleum User
71sierragrande's Avatar
Has anyone had experience with a reman steering gear from LMC? The catalog shows them selling for $230+core.
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto
2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto
71sierragrande is offline   Reply With Quote
