![]() Join Date: Nov 2002
Does this sound like a far fetched idea?
Like I posted earlier, we're putting a B&M 177 on my son's 396 and would really like to keep it under a cowl hood. I've spoken with a couple of board membbers that run close to teh same combo and they thig if the air cleaner is low profile enough that it should work. Now I'm wondering how to get cold air to the blower. What do you think of removing the headlights and using those for the air inlets, and taking the running lights in the grill and making those into headlights? I know they make them small enough, it's just a matter of finding a clear cover. Here's the piece I was thinking of using to start the conversion over.
Am I having too much time on my hands, or does this make sense from a performance standpoint? http://www.google.com/products/catal...d=0CFwQ8wIwAw# |
Re: Does this sound like a far fetched idea?
Here's a pic
i would have to see it, but just the thought of what i think it would look like isnt appealing, and getting the headlights to work properly like you are describing wont be as easy as it sounds
68 SWB Fleet 383 |
the boat guy
I'd keep the factory headlights and run the air ducts on a 69-72 front bumper where the turn signals go.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
no.
If the back of the cowl hood is open, It should get enough air.And then you could watch that monster twist from the drivers seat.I don't like the looks of all the pipes running under the hood.JMO
I am a Referee of life.
move the batt to the bed,use a one wire alt and cut a hole inboard of the lights in the rad support for the air inlets.Then you should get cool air from in the grille for the blower, and you can use the lights.I think you'llneed to go one wire on the alt to get the volt reg out of the way.you may even be able to run air filters between the grille and rad support.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Old Skool Club
![]() Join Date: Jun 2001
Plenty of old-school drag racers ran the air intake ducts beneath the front bumper as suggested in an earlier post. Only problem is you gotta be sure it doesn't suck up any water if you try driving it through a deep spot or a lot of rain.
The suggestion about the cowl hood would have the cooler, denser air at the base of the windshield which would also be a higher-pressure air supply. That's what makes a cowl induction work. Or, swap in a GMC grille, with 4 headlights and use the inboard buckets as your point of modification to route the air. But, you'd still have to make some holes in the radiator support...
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Do it like the NASCAR guy's do it. Cut a hole into the area at the base of the windshield and pull the air from the existing cowl vent. You'll have to make a custom air cleaner housing but you may have to do that anyway.
#10 | |
The problem with the low headlights is that you may not get them to aim properly. You may be blinding everyone at night. It's possible, but I think the other ideas posted are better than the headlight idea.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
