Old 08-27-2011, 05:39 PM   #1
amccomb
rear end
I recently bought a 66 k10, since it had been sitting for a few yrs before I bought it. I decided to change the fluid in the diff's. Come to find out the rear end is shot. I am thinking about ordering parts from LMC Any other better options out there?
amccomb is offline   Reply With Quote
Old 08-27-2011, 08:59 PM   #2
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: rear end
If your needing a gear set and master rebuild kit I would do a search for drive line shops. I used one that sells on ebay to order my carrier and gears and had a local guy build it for me. I didn't go thru ebay just contacted the shop direct. Very knowledgeable. I don't recall their name, it's some where in my build. They are in TX.
Alan's Classic is offline   Reply With Quote
Old 08-28-2011, 02:06 AM   #3
Captainfab
60-66 Nut
Re: rear end
If you can't find the parts you need locally, I would go directly to the differential parts suppliers.
Here's a couple that have a good reputation.....
http://www.ringpinion.com/
http://www.drivetrainspecialists.com/
http://www.reiderracing.com/
http://www.tomsdifferentials.com/
The parts can also be found at Summit Racing and Jegs
Just so you know, the GM truck 12 bolt was used from '63-'79 in the 4x4's and thru '82 in the 2wd's.
Old 08-28-2011, 09:12 AM   #4
T Smith
T Smith's Avatar
Re: rear end
I bought my ring and pinion (Richmond) and installation kit from Jegs and an Eaton posi unit and 2 new axles from Summit and had it set up locally.
T Smith is offline   Reply With Quote
Old 08-28-2011, 09:10 PM   #5
amccomb
Re: rear end
Thanks for the info guys.
Old 09-05-2011, 10:46 AM   #6
amccomb
Re: rear end
I just bought all the parts to rebuild the rear end in my 66 k10. Any advice about doing it myself?
Old 09-05-2011, 11:06 AM   #7
rideblue00
rideblue00's Avatar
Re: rear end
Jegs and Summit should have DVDs on the subject. You need a few special tools which they have as well. But since i havent set any up before, in thinking the most important part is getting the gears to mesh in the proper pattern. I have read that the pinion crush sleeve can only be used once. If you do it yourself, get a dvd and a few extra crush sleeves and an assortment of shims. And prussian blue to get the mesh pattern correct. And find a freind that has done it before, lol.
rideblue00 is offline   Reply With Quote
Old 09-07-2011, 09:19 PM   #8
amccomb
Re: rear end
I am having a hard time finding a descent aluminium differential cover, anyone have any ideas?
Old 09-08-2011, 12:23 AM   #9
Captainfab
60-66 Nut
Re: rear end
That depends on what you're looking for and how much $$. Moser makes a nice rear cover with a built in girdle, but it isn't cheap. I believe Summit has some finned aluminum covers for the truck 12 bolt.
Old 09-08-2011, 05:15 AM   #10
amccomb
Re: rear end
I spent way more than I wanted to on the rebuild parts. I am trying to get a descent priced diff cover. You think I can get away with just a chrome steel job? How much of a difference would a nicer cover make?
Old 09-09-2011, 12:37 AM   #11
Captainfab
60-66 Nut
Re: rear end
An aftermarket differential cover is not going to make any difference in the operation of the differential. If funds are a little short, I would just put the stock cover back on for now, and apply what funds you have towards getting the differential assembled correctly. Changing the cover later on is very simple.
Old 09-07-2011, 09:42 PM   #12
Max1775
Max1775's Avatar
Re: rear end
Google GM 12 bolt cover. I saw a ton of them.
Max1775 is offline   Reply With Quote
