Old 08-28-2011, 04:45 PM   #1
1LowToy
350 blocks
I have a 73 350 motor, how can i tell if it's a 4 bolt or disired block? Right now it's too greasy to touch, so where and what do I look for? Fondling around dirty things is not my favorite.
1LowToy is offline   Reply With Quote
Old 08-28-2011, 05:28 PM   #2
bigwheel15
bigwheel15's Avatar
Re: 350 blocks
There should be a casting number on the back of the block, I believe there is one on the front by where the alternator mounts as well.
bigwheel15 is offline   Reply With Quote
Old 08-28-2011, 05:37 PM   #3
LONGHAIR
Re: 350 blocks
As long as you are not intending to rev it's guts out, it doesn't really matter.
A 2 bolt block will stand up to the average performance build just fine.
As long as the block is solid and not execssively worn, it's good to go.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 08-28-2011, 07:50 PM   #4
PaRedneckRiders
Re: 350 blocks
I would say just pull the oil pan and check the mains.
PaRedneckRiders is offline   Reply With Quote
Old 08-30-2011, 07:47 PM   #5
85gmcguy
Plays with trucks
85gmcguy's Avatar
Re: 350 blocks
Check the casting number (passenger side back of the block). If it ends in 010 it's either a 4 bolt main or heavy duty 2 bolt main. Either is a good starting point if it's not been overbored by .060 yet.
Gary
My Dad's Old Truck
1985
85gmcguy is offline   Reply With Quote
Old 08-30-2011, 07:52 PM   #6
kris's66lwb
resident wrencher
Re: 350 blocks
010 i beleive is the code for a 350 it wouldnt telly you main bolts or any thing there should be other castin marks and or stampings showing nickle content and main bolts and all that good stuff
kris's66lwb is offline   Reply With Quote
Old 08-30-2011, 10:13 PM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
Re: 350 blocks
my 78 jimmy isn't (stock 305) but it's supposed to be "period correct" 350 with 4 bolt mains
this is what the back looks like and the front numbers
you can usally blast back there with a pressure washer to see them
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 08-30-2011, 10:02 PM   #8
BigBlocksRule
Re: 350 blocks
Look for 010 and/or 020 under the timing chain cover, they're the better blocks, either 2 or 4 bolt. As long as it's a daily driver and not beat hard, a 2-bolt is fine. If you like driving it like you bought it at Harbor Freight, you best start with a good 4-bolt block. Gotta pull the pan, there are no single 350 castings from this time that tell if it's 2 or 4 bolt other than 400's.
BigBlocksRule is offline   Reply With Quote
