Old 08-29-2011, 08:33 PM   #1
Slowtruk
Slowtruk's Avatar
Anyone use this gas tank from classicparts?
Here it is. Claims it has everything needed to move it for only $199.95
http://www.classicparts.com/1963-66-...tinfo/23-928A/
Slowtruk is offline   Reply With Quote
Old 08-29-2011, 08:49 PM   #2
stealth_weapons
Re: Anyone use this gas tank from classicparts?
looks like it is missing a filler neck and cap. IDK, i have been to classicparts (located in Kansas City, MO)and bought some parts but, didnt even think to check out the fuel tank.
the Stealth Weapons 63 project, all comments, advice, and critiques welcome!
http://67-72chevytrucks.com/vboard/s...d.php?t=438235
stealth_weapons is offline   Reply With Quote
Old 08-29-2011, 08:52 PM   #3
lakeroadster
Appears to simply be the "Blazer" style tank...
lakeroadster is offline   Reply With Quote
Old 08-29-2011, 08:55 PM   #4
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Says spout might need mods...so it used existing spout ?
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 08-29-2011, 08:56 PM   #5
Slowtruk
Slowtruk's Avatar
Which is pretty much what everyone uses, correct? This seems like a cheap and easy way to accomplish that
Old 08-30-2011, 07:39 AM   #6
lakeroadster
Not everyone.... in this case cheap and easy will result in a tank that hangs down and is visible from the rear and side of the truck. The following link shows all the different styles and includes photos and how-to articles: http://67-72chevytrucks.com/vboard/s...ht=tank+thread
Old 08-29-2011, 08:57 PM   #7
losthope
losthope's Avatar
truck shop also sells a kit for $195.00 looks to be the same thing.......
http://www.truckandcarshop.com/
page 78 here: http://www.scribd.com/full/17608177?...qy43h7a9pmdutn
and lmc sells a kit for $199.95 they all look the same in the catalogs ! i too am curious to who has used one of these kits
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 08-29-2011, 10:06 PM   #8
Slow Build
Slow Build's Avatar
Here is an earlier thread on the subject.
http://67-72chevytrucks.com/vboard/s...lazer+gas+tank
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 08-30-2011, 12:49 PM   #9
kieth
kieth's Avatar
I used this kit, but did change it a bit. It worked out well. Kieth
Here is how it looks, scroll through the pictures and you can see the different steps we took making it work. Kieth
1. http://kieth.smugmug.com/Trucks/66-G...005088_DrSmCmf
2.http://kieth.smugmug.com/Trucks/66-G...4_sr9cCz6-A-LB
3. http://kieth.smugmug.com/Trucks/66-G...270029_44JXfxh
be sure and look through the gallery for other details, if you have questions call me Kieth 918-446-2245
kieth is offline   Reply With Quote
Old 08-30-2011, 08:14 PM   #10
Slowtruk
Slowtruk's Avatar
Beautiful photos man. How long did it take you start to finish to restore the truck?
Old 08-30-2011, 08:35 PM   #11
lakeroadster
Nice tank install and beautiful truck, really like the color.
I think the key on these tank installations is to mount them between the frame rails, up to the top of the frame. When folks mount them under the frame, that is when they are tail draggers. Trucks with rear roll pans allow more of the tank to show also.
Old 08-31-2011, 08:52 AM   #12
kieth
kieth's Avatar
There really is not enough room to mount this tank on the top frame flange, I mounted mine to the bottom of the frame flange so it could be removed without removing the rear bumper, rear crossmember, etc......thank goodness I did it that way , we have had to drop the tank 3 times since installing it due to sending unit wireing connections, fuel pump problems, and having welded the nuts to the top of the lower flange made it a simple process. JMO Kieth
This tank is bolted to the bottom of the frame flange and I used the straps that came with it, so I do not think it is going anywhere..........
Old 08-30-2011, 07:55 PM   #13
64fleetside
I put one in a burb, works great.
64fleetside is offline   Reply With Quote
Old 08-31-2011, 01:25 AM   #14
carney
The classic parts and lmc catalogs say this fits 63-66 trucks. Does anyone know if that's because the frame width or because of the coil vs leaf rear end? I've got a 60, but with a coil rear end and was wanting one of these tanks.
carney is offline   Reply With Quote
Old 08-31-2011, 08:56 AM   #15
kieth
kieth's Avatar
My 66 gmc is on coils......(actually air bags)
Old 08-31-2011, 08:43 AM   #16
kieth
kieth's Avatar
I think it is because of the frame width, I did go out and take a picture from the rear of my truck yesterday......
here is that picture:
http://kieth.smugmug.com/Trucks/66-G..._jb2dtZs-XL-LB
Thanks for the compliments guy, I started it 8 months ago, my first ever build, it seems like an eternity, but you have to realize that I own a used Truck Dealership Freightliner, KW, Pete, we build dump trucks, so we worked on it when we had time, and unfortunately this last year we had a lot of time since business has been so slow, but we learned a lot and had a great time. I found a lot of ways to save money on these builds as I went along, now have 1 65 chevy that we are going to hot rod and slam (to sell) and another 66 that is a BBW, factory air, 283, powerglide, p/s , custom that we are going to restore to stock condition after making it a SWB fleetside.......will see if there is any money in restoring these trucks and reselling, the green truck is my daily driver and I will not sell it.
