Old 04-09-2003, 10:53 PM   #1
400ex
light, fan relay install
I want to install relays to run my headlights and, in the future, an electric fan. I have converted my truck to a 105 amp 12SI already.
Where have you tapped into the electrical system to run a hot wire to the relays?
James
400ex is offline   Reply With Quote
Old 04-09-2003, 11:08 PM   #2
Johngear67
The Mighty Blue Bottle
if you have a remote selinoid,place where hot when in run
1967 Chevy C 10 Custom
350 780 cfm 467 lift 278 dur
ported&pollished
2400 stall 350TH
B&M shifter
175 shot of nitrious
Johngear67 is offline   Reply With Quote
Old 04-10-2003, 11:55 AM   #3
Alex Hayley
I believe I understood your question...if I have not ignore what I am about to say.
As was explained to me by XXL...I hope he does not mind me quoting him...
"As for a solid 12 volt source, there isn't one that big in the factory fuse panel. You'll want to run one from the battery. Make sure you use a good 12 gauge or bigger wire, fuse it AT THE BATTERY, and use grommets when going through sheetmetal. If you plan to have other accessories that require power, you may want to bring the battery lead in and create a "bus" with it. That way you can just tap that connection any time you need battery power. "
Hope this helps...
Alex Hayley is offline   Reply With Quote
Old 04-10-2003, 01:20 PM   #4
MandarinSixSeven
Seasonal Poster
MandarinSixSeven's Avatar
I was going to ask a similar question...but what want to do is something like this. I just want to know what relays I would need? Anyone know?
67 GMC Short Step
350/4-Speed/3.08 Posi
Front/Rear Sway Bars
Kelowna BC, Canada
Member of DTPW
MandarinSixSeven is offline   Reply With Quote
Old 04-10-2003, 01:57 PM   #5
Alex Hayley
I got a couple four pin 30A relays from autozone. $5 a peice. Hook them up right after the dimmer switch on the way out to the headlights.
