700R4 in a 67 pickup
Do you have to change out the stock cross member to run a 700r4 Tranny? The truck had a TH400 in it originally. Thanks for any help with this.
JRBECK64 |
Re: 700R4 in a 67 pickup
You should have no problems mounting the 700R4 with that crossmember. You will however, have to move it to a different location on the frame rails. I am planning the same with my 68 short 454 truck that is currently under construction. P.S. Don't forget to get the tv cable adjusted properly or it could be bad news[ if you have'nt had one before] .Jim
![]() Join Date: May 2002
I left the crossmember in the stock location, and just added a plate to move the mount to the new location. Mine had a TH400 originally as well.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
Thanks for the info. That will be helpful. When I put one in my Sons 64 Shortwide I had to get a different crossmember and it was kinda spendy so Im glad I dont have to be out that money.
JRBECK64 |
![]() Join Date: Jul 2006
Two things to think about...
For $40 or so a CPP tubular crossmember is a good deal if the above are important to you. It bolts on the bottom flange of the frame only and allows access to pan bolts.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
#6 | |
JRBECK64 |
Porterbuilt has a nice tubular crossmember too. Great guys to work with and less a headache than CPP. Go with porterbuilt.
Never wrenched a day in my life and now... Im doing a frame off restoration on a 1968 C10 with a Porterbuilt Dropmember, Acuair E-Level kit, Boyd Welds Gas tank and mild c-notch. Click here to view my build |
Crossmember is on its way and even bolts in the same holes as the ones that are in the crossmember thats in it now. Thanks again for all the info.
JRBECK64 |
