09-03-2011, 06:35 PM | #1 |
ANOTHER Horn Problem - Need Help Please
I'm redoing my interior and part of it is a new steering wheel. While I had the wheel off, I took off the turn signal mechanism and installed a new upper bearing. When I try to put it back together now, I got as far as torquing the steering wheel down when the horn started honking. From messing around with it, I know it has something to do with the spring loaded copper button on the turn signal mechanism (see first picture). If I press the copper button with my finger, nothing happens, but when I put the (brand new) turn signal cancelling cam on (see second picture), and push into place, the copper button does down and the horn starts honking. Am I doing something wrong, or do I need to by a new turn signal mechanism (which is only a year old) or what?
BTW, a good little tip someone passed on to me - Instead of pissing all my neighbors off with the horn, I connected the wire to a light bulb to see when the horn was on or off. Worked great... Last edited by srvivor71; 09-03-2011 at 07:40 PM. |
09-03-2011, 08:32 PM | #2 |
Re: ANOTHER Horn Problem - Need Help Please
bump for some help.
09-03-2011, 10:56 PM | #3 |
TTT -C'mon, I know someone out there must know about this...
09-03-2011, 11:06 PM | #4 |
it looks right from there, might need more pics of what the horn set-up is above the cancel cam. If the pin on the cancel cam is hitting metal I think you'll have a problem. The instructions with those things usually tell you to cut some off to shorten it.
If I understand the horn wiring correctly, the horn grounds to the metal in the column, mine grounds to a steering wheel bolt. So if a wire isn't insulated/pinched, or that cancel cam pin hits metal, you'll sound the horn. Might be just a bit too long so it contacts something only when you tighten down the wheel nut. Just my guess with very little experience. |
09-03-2011, 11:33 PM | #5 | |
09-03-2011, 11:57 PM | #6 |
20' Daredevil (Ret)
It's been too many years since I had mine apart.... but grounding that copper button will operate the horn relay, which of course blows the horn. The horn doesn't blow when you push the copper button because your finger isn't grounded. If you touch the button with a test wire connected to ground, the horn will blow.
That doesn't exactly answer your question..... just trying to help you with a bit of info. The brass ring on the cancelling cam is getting grounded, which then grounds the copper button. What dcasalena said about shortening the cancelling cam pin might be right..... it kinda rings a very faint bell with me, but like I said it's been way too many years.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
09-04-2011, 08:25 PM | #7 |
ttt
09-04-2011, 08:56 PM | #8 |
Not sure if I can help but here is a exploded diagram of a column...maybe the switch contac support may be the culprit...item35........and just a tip that I use is to place a penny on the shaft end to pull the steering wheel with the puller.....saves on marking up the shaft
09-04-2011, 10:03 PM | #9 | |
Also...make sure the BLACK wire from the turn signal switch to the horn relay is not grounding in the column...this happens sometimes when replacing a turn signal switch if one is not careful threading the T/S harness through the column. |
09-05-2011, 08:29 PM | #10 | |
09-05-2011, 10:49 PM | #11 | |
Connect your test light lead to a good GROUND and with all three connectors plugged in at the horn relay...touch your test light tip to the green wire connector on the horn relay...the test light bulb should remain off. If the test light bulb lights on the green wire...the horn relay is bad...replace it...end of problem. If the test light bulb does not light when testing the green wire: To check for a short to GROUND: Connect your test light lead to a B+ source...then when you touch a GROUND source ( like a bolt or sheet metal ) with the tip of your test light the bulb inside your test light will light verifing you have located a GROUND source. So to check to see if your horn wire is shorted to GROUND: Disconnect the BLACK wire at your horn relay and touch the connector with the tip of your test light. If the test light's bulb remains off...then you know there is no short to GROUND in the T/S switch harness. Repeat this test with the cancelling cam installed and see what the light does. |
10-08-2018, 04:41 PM | #12 |
First of all, thanks for all this info. I just replaced my turn signal switch to only put everything back together. Hooked battery up and horn blared!!!! Through trial and error, what I found out was the POS reproduction parts LMC sell have a different backing plate where the black wire attached. That STUPID plate was grounding out on the column causing the horn to engage. So incredibly frustrating!! However, filed the tab down and no more horn blaring.
10-08-2018, 04:53 PM | #13 |
20' Daredevil (Ret)
Old thread revival, nothing wrong with that (it proves you searched!), and I'm glad you got it to work correctly!
10-08-2018, 04:56 PM | #14 |
It's amazing the trouble we have to go through to modify aftermarket parts so that they will work on our trucks...It's like nobody at the factory or parts supplier has actually used the parts! If it's not NOS, you'll be wallowing, filing, rewiring, cutting and welding, sanding and repainting, etc, etc.
Glad you worked it out!
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
11-04-2018, 05:47 PM | #15 | |
I’m glad you got your horn worked out!!! I know the feeling. Glad it was a simple fix!! |
Tags |
horn button, horn connection, horn honking, horn problem |
