Old 09-03-2011, 07:48 PM   #1
sinnersahuayo
1965 c10 v8 with carb problems
edelbrock carb electric choke turns on. stays on for like 5 mins and then truns off
sinnersahuayo is offline   Reply With Quote
Old 09-03-2011, 09:04 PM   #2
PGSigns
PGSigns's Avatar
Re: 1965 c10 v8 with carb problems
If it is turning off how is it wired? Have you checked to see if it is adjusted correctly. When I got my truck it was way off and the choke was not working correctly.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-03-2011, 11:04 PM   #3
sinnersahuayo
i have checked for vac leaks and no leaks. i took the carb off the truck and cleaned the inside of it and still the same thing. its a 1406 carb form edelbrock. before i cleaned the carb choke setting was on the normal notch and did not run on. so i moved the choke setting clockwise 2 notch and started for a 1 min. now the setting is at the last notch and runs for 5 min. should i remove the 3 screws and check or adjust what in side. i have never gone inside the a electric choke.
Old 09-04-2011, 10:31 AM   #4
PGSigns
PGSigns's Avatar
What is the carb doing that makes you think you have a choke problem? Is the choke not setting when cold? What does the choke do if when cold you press the pedal down one time? Will it set? Normal centered position works good most of the time. You should be able to set the choke, start the motor and have it run at fast idle. After about a minute or so hit the gas a little and have it return to normal idle.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 09-04-2011, 10:52 AM   #5
sinnersahuayo
the truck start when cold. when it on i have press the gas pedal nothing.
Old 09-04-2011, 11:13 AM   #6
PGSigns
PGSigns's Avatar
When you say "press the gas pedal nothing" do you mean the choke opens? If so it should pull open when the pedal is pushed.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 09-04-2011, 11:17 AM   #7
sinnersahuayo
when i press the gas pedal the truck rev( am press the pedal) then it goes to the normal warming cycle. then after 5 min it shut off. i have to wait until its cold to start it again. i have tried starting it after it shut off with no luck. i have to use quick start and then it start.
Old 09-04-2011, 05:24 PM   #8
PGSigns
PGSigns's Avatar
So this is a hot start problem. Once warm you should be able to just hit the key and it start. Are the idle are screws working and when you pulled it apart what did you set the float levels to. Both of these can cause a hot start problem. Also have you checked the wiring on the choke to ensure it is opening up as it should?
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 09-04-2011, 05:30 PM   #9
sinnersahuayo
i 12 volts from the fuse box i checked with my volts meter, i just give up. i bought a new one now i have to eat bread and drink water until next paycheck. i took her for a long and harsh ride and it was wroth it. the carb handle. now i need to work on the bed and the seat. engine done.
