![]() Join Date: Oct 2010
Widened wheel tubs
Anyone have pics of their stock looking widened wheel tubs for a 66 Fleetside?
Looks like I'm going to have to widen mine. From what I can tell, they at least have to be widened so the inside edge lands on the wood and not a bed strip. Anyone make widened fiberglass (or metal) stock style tubs (wheel house)? Thanks again! By the way, I did a thread on this about a year ago, but didn't know if anything new has come up.
TAZ BUILDS 1966 GMC Suburban 1963 GMC Suburban Patina frame-on FOR Sale 1966 C10 Short Bed (2010-11) Monthly Updates 2015 C10 Pics with my '72 Montego GT 429/521 build 1963 Pro Street C10 back halved. Frame off I did back in 1990 Pics / Video Last edited by tazattitude; 09-04-2011 at 02:07 PM. |
Re: Widened wheel tubs
You don't have much wood between the stock wheel tub and the next bed stip. If I remember right it's only about an inch, but if that's all you need it will be worth it. I widened mine by 2 1/4" but I also made a raised bed floor that's probably not going to be topped by the original style wood kit, so I wasn't worried about where the inside edge of the tub was going to fall. I just measured for some 12" wide tires and put the support where I wanted then measured how much to widen the tub. I'll figure out the bed wood when the time comes. Check my build thread about 4 pages from the end and let me know if you have any questions.
http://67-72chevytrucks.com/vboard/s...54#post3194654 |
![]() Join Date: Jan 2011
I am doing a set now that we are making 2 inches wider by using 2 tubs. Mine were thin and a little beat up on the inside but the side that met the bed were good. I got a pare from Top Banana and cut the first inch off of them and then cut three inches off the old ones. The fit was almost perfect, the stampings are very close.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#4 | |
#5 | |
It's Better With Nitro
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
Looks great Vin. Looks like you didn't line up the areas where the hole lines up with the bed strips. Any problems? Or did you just smooth that out?
@blackmopar I just ordered a set from TB about an hour ago. I did a search for 'house' on their website and it brought them up.
TAZ BUILDS 1966 GMC Suburban 1963 GMC Suburban Patina frame-on FOR Sale 1966 C10 Short Bed (2010-11) Monthly Updates 2015 C10 Pics with my '72 Montego GT 429/521 build 1963 Pro Street C10 back halved. Frame off I did back in 1990 Pics / Video |
"Where were you in '62?"
![]() Join Date: Jul 2004
Give me a couple weeks or months!
![]() I'll post mine! http://67-72chevytrucks.com/vboard/s...d.php?t=321173 Then: ![]() And now: ![]() ![]() These tubs and floor less the NOS bottle, fuel cell, and bowtie emblem: ![]() Or this floor with the tubs: ![]()
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
I was trying to avoid landing the edge of the tub on the mounting strip because I have to notch the bed wood further inboard of that strip to clear the width of the tire. Let us know how you like the tubs you purchased.
are suburbans wider?
Just found this one on ebay. Hope it helps.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. Last edited by Slow Build; 09-04-2011 at 09:41 PM. |
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
I am a big fan of the extra wide stock looking tubs.....It gives a real leathal look i think . My Pro street truck tubs are probaly a little wider then your thinking but I took out my rolled tubs and built a more wide factory look as well by doubling out two wheel tubs.
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[ 1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123 1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909 1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625 Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic Aluinum Radiator Dealer pm for details |
Thanks Guys!
I like the look of the tubs on the yellow truck. Pretty much what I was looking for. I was thinking that the holes on the front and rear were supposed to line up with the bed strips. On that one, it does not. Looks great though. Thanks again!
AH, okay. understand.
tubs are on the way. I'll take part of my old tubs (probably the nearest to the bedside) and use a majority of the new tubs I'm getting. @1Bad62Pro/Street I had something like that polished alum bed in my truck I did 15 years ago. Going more for a stock style look this time. ![]()
Found another one in my archives.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
#15 | |
![]() Quote:
Where did you get the aluminium? Make the roll beads your self? Pre-formed? Pops keeps saing that if I line the sides and head board with aluminium it will draw in moisture between the aluminium and metal causing rust. Did you experience this? Just a few questions! ![]()
#16 |
That's exactly what I'm looking for slowbuild!!! Thanks for the pic.
1Bad62Pro/Street Here are some other pics of that truck Back right before purple was the 'bomb' Did the build in 94 or so. Sold it in 2001. Never had any problems with any moisture.
#17 | |
![]() Quote:
#18 |
A little better detail on this one.
#19 |
I ended up widening my tubs on Th. Got them in primer on Friday.
I widened them 3.5 inches. I decide not to 'double' them like the white one just posted and the red one. I didn't want to go as wide as them (I think I ended up about 3" narrower than the white and red one). I will have to re-arrange the wood, but I think it will work out though. I used this black tub as an example to go by. ![]() ![]() ![]() ![]()
#20 | |
#21 |
I know this thread was referenced from another thread so I'll add to the outcome of my tubs.
See pics... ![]() ![]() @chad64chevy Sorry I missed your question. I believe you had pm'd me on this though. I used 3/8" bolts I did not shave the bolt heads
#22 |
I do like the way they rounded the corners on the white tubs. Nice clean look!
#23 |
Did you flatten out these areas? I can't tell from the picture of them in primer.
#24 |
meowMEOWmeowMEOW
Not completely finished, but wider is better.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#25 |
By the way, your tubs look good!!
