09-07-2011, 12:41 PM | #1 |
Chevys Kick A$$
Toggle switch for electric fuel pump?
Hey so on my '79 I went with an electronic fuel pump because I kept having issues with my mechanical. Now it works just fine but my question is I have it wired to come on when the keys on. With doing new wiring and putting a stereo in I have had to turn the key to on a few times to check things and just let the pump run briefly. Is this setup ok or should I run a toggle switch for power to the fuel pump. Any pros or cons or input would be greatly appreciated! Thanks
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
09-07-2011, 01:22 PM | #2 |
Re: Toggle switch for electric fuel pump?
I wouldn't sit around with my Fuelpump running.
While listening to radio. Kinda dangerous Toggle switch is good idea. And if you hide it. It works as anti theft too. Posted via Mobile Device |
09-07-2011, 02:05 PM | #3 |
You could hook it too a hobb switch that only allows the fuel pump to run when the engine has oil pressure. It has a two fold benefit, one the pump will not run with just key in the run position (why don't you have the stereo wired to the Accessory side of the fuses like it is supposed to be?), two the fuel pump will cut off if the engine were ever to lose oil pressure saving it from catastrophic failure.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
09-07-2011, 02:24 PM | #4 |
Chevys Kick A$$
I like the hobb switch idea that's cool. I am not listening to the radio I just hooked it up to make sure it worked. I was fixing a fuseable link and my dash lights and rewiring a couple things this week and had to turn the key on to make sure it worked properly. I just didn't like the idea of the pump being on with the key when I was doing the wiring work that's what made me ask about toggle switches lol.
09-07-2011, 04:29 PM | #5 |
yeller
I personally woul replace the faulty mech fuel pump over running an electric pump...less hassle and more reliable IMO.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
09-07-2011, 08:26 PM | #6 | |
The One And Only !!!
Couldn't agree with Jeff more !!! I've been stuck on the roadside 3 times from sorry frame mounted pumps (different brands), If my 502 had mechanical pump provisions that's what would have went on the first time. I now keep a spare in the glovebox just because there unreliable as hell....
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
09-08-2011, 10:31 AM | #7 |
78K & 79C Jimmys
i put 2 switchs in one the dash,and one under the dash,ran it in the loom to the back.
i wouldn't run one without it. say you crash,can only move a bit in your seat,smell gas, can't reach the key and the engine is still running..... i'd wana be able to turn it off or my passenger can the second switch is hidden for anti theft......may start.....and just die crank, crank,crank,crank,crank,crank,thud(thats my bat lol)
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
09-08-2011, 11:29 AM | #8 |
My fuel pump is wired to a rocker switch on my dash next to my headlight switch. I would not run an electric fuel pump without some sort of switch in my opinion.
09-08-2011, 02:53 PM | #9 |
Chevys Kick A$$
Cool sounds good I already got a toggle switch hidden up underneath the dash I will use for just this. Yea I didn't want to go with an electric pump. But after trying 2 brand new mechanicals with no luck and trying to mess with the rod I just gave up on it! The trucks just my mud truck and bashing truck so it aint going to be going on any long road trips just up in the mountains is all.
08-21-2015, 12:01 PM | #10 | |
08-22-2015, 11:42 AM | #11 |
Plays with trucks
OK, not to beat the subject to death but I run my electric fuel pump (Holley Red) with a relay, through an oil pressure shut-off switch, and use a momentary-on push button type switch for manual over-ride and testing purpuses. Manual over-ride makes it easier to get fuel to the carb after it's been setting for a while.
Gary My Dad's Old Truck 1985 |
08-22-2015, 05:35 PM | #12 | |
10-19-2016, 04:08 AM | #13 | |
'84 K10, SM465, NP208, 3.42 Gears, 33x12.5-15 GM 4 bolt 880 roller block, 062 Vortec Heads Comp Cams XR258HR-10, MSD Street Fighter HEI Edelbrock: Performer Intake 2116, 1405 Carb Long tube headers, 2.5" duals to Flow Master Super 40's Vortec Engine Build |
09-09-2011, 04:50 AM | #14 |
You COULD put a switch in series with your ignition switch. Leave it ON all the time except where you feel the truck might be tampered with or you want to have the ignition ON with the motor OFF. I have had my electric hooked up to the ON side of my ignition switch a couple of years no problems. With a crate vortech engine there was no boss for a fuel pump for my 4 barrel carb.
09-09-2011, 02:24 PM | #15 |
The oil pressure switch is typically how the factory does it, as well as an inertia switch which kills the fuel on large impacts or roll overs. When I used to race Jeeps, on electric fuel pumped carbed engines you quickly discovered that when you rolled one, and were upside down, having gas pour out the carb on to your body was a sucky idea. The only reason electric was used was to keep up with two 660 center squirters at 7000 rpm.
On fuel injection engines not quite so bad, as they will continue to run upside down, at least until the sump drains from oil and they seize, or the oil pressure\inertia switch shuts the fuel pump off. I would stick with the mechanical pump if it was possible, though. Cheap & reliable are two great qualities to posses in car parts. |
09-09-2011, 06:07 PM | #16 |
The oil pressure switch works well until the truck sits for more than a day and then your cranking and cranking and cranking until you get enough pressure to get the pump to prime. You almost need a momentary prime switch if it isn't something your going to drive everyday.
08-18-2015, 11:31 AM | #17 |
FWIW---electric pump PLUS mechanical works very well if your truck has been setting for any length of time and the carburetor leaks down as some tend to do---saves starter/battery from having to grind long enough to refill--just switch electric on for 30 seconds. Besides---all that grinding to start your truck is embarrassing!
Stepsides look like real trucks! Smitty |
10-19-2016, 03:31 AM | #18 | |
By the way my 87 Dodge sits for long periods of time and solved the "crank til it's dead" fuel problem by just installing one of these valves (http://www.ebay.com/itm/like/1915585...&ul_noapp=true) in-line close after the fuel pump. No more slow drainage of the fuel. Once again thanks for the info. |
10-19-2016, 04:21 AM | #19 | |
10-19-2016, 11:36 AM | #20 | |
08-18-2015, 12:45 PM | #21 |
i ran the mechanical and the electric pump in sync in my 84 blazer. when the mechanical pump would vapor lock, i would flip the toggle and run the mechanical. worked like a charm
1967custom |
08-18-2015, 03:10 PM | #22 |
Too answer your ? no it dosn,t hurt any thing if you have it on intermittently checking some thing out.
83 c10 long Box Daily Driver 90 Jimmy parked 98 Road King/ 06 Road Glide In memorium 63 impala SS/ 65 Chevy Panel 65 GMC Short Box/ 68 Camero |
08-18-2015, 07:06 PM | #23 |
driving is in my blood
I've always run a toggle switched hidden somewhere. Ran frame mounted electric pumps [carter and holley] for years without issues as well.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
08-18-2015, 10:04 PM | #24 |
The pump should be on a relay and the relay should be energized when the key is in the crank position, or the key is in the run position and there is oil pressure. Having the relay turn the pump on when the key is in the crank position ensures the fuel system is priming when you're cranking. Having the relay turn the pump on when they key is in the run position and there is oil pressure ensures that the pump won't run if the motor isn't.
08-20-2015, 09:10 AM | #25 |
Wire it like Kalbert says is the correct way to do it .
Also I am not a big fan of being in a wreck and unconscious and the motor not running but the fuel pump still running . In a front end collision most likley you are going to damage the fuel system . Good chance for a fire while unconscious . Not my preferred way to go . That switch may as well be a million miles away . |
