Old 09-07-2011, 01:07 PM   #1
dukcaln
dukcaln's Avatar
1 pop under full throttle while cruising...
So I was driving the truck the other day to the muffler store to get a gasket for the leaking header and was cruising around 35 or 40mph. Well I was on a open stretch of country road, no other cars around and decided to put her through some running... so I mashed the throttle down and pop... then I backed off and mased again and she kicked down great and took off like a rocket...... my question is, could it be timing or carb adjustment.... I just replaced the plugs after getting my timimg issue solved... current set at 12-14 degrees... Only thing I can think of is carb adjustment, which I really have not takled..... any ideas...
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP
SOLD 1972 chevy c10
dukcaln is offline   Reply With Quote
Old 09-07-2011, 04:38 PM   #2
dukcaln
dukcaln's Avatar
Re: 1 pop under full throttle while cruising...
anybody..................
SOLD 1972 chevy c10
Old 09-07-2011, 04:43 PM   #3
Bears63
...just another truck junkie..
Bears63's Avatar
Well, when was the last time you had mashed the throttle? If it had been a while then some hesitation and popping will occur until things are cleaned out a bit. A little carbon build up in that intake can do that.
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 09-07-2011, 05:12 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
There is a chance that your issue is in the carb. It may be your accelerator pump is not working properly
Frank
Old 09-07-2011, 06:47 PM   #5
danleaman
A one time pop is pretty hard to diagnose, if it did it every time you mashed on it I would start with the accelerator pump or fuel delivery system. But only once? Was the pop out of the carb or exhaust, you mentioned that you have a leaky header gasket.
Just a thought, I could be wrong.
Dan
danleaman is offline   Reply With Quote
Old 09-07-2011, 08:38 PM   #6
bigguy69
dazed and confused
bigguy69's Avatar
Sounded like it just needed its leg stretched.
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 09-07-2011, 10:18 PM   #7
dukcaln
dukcaln's Avatar
to me the pop was out of the carb......
SOLD 1972 chevy c10
