09-09-2011, 11:38 PM | #1 |
How much does a 2.5/4 drop help handling?
I really want to improve the handling of my truck. I've got a factory front sway bar. I've got an Iroc bar for the rear but after reading in the suspension forum here I don't think I will use it. I've read the camaro bar is too much for the rear and can hurt handling.
So what else can I do to improve to handling? I'm not really big into dropped trucks. I have been considering 2.5/4 drop just to improve to stance a bit and lower the center of gravity. So my question is this: How much will a 2.5/4 drop improve handling and reduce body roll? Will the drop adversely affect ride quality? I am running 275/60R15 tires. Are there any foreseeable issues with this combo? The truck is a '72 shortbed. |
09-10-2011, 09:01 AM | #2 |
Re: How much does a 2.5/4 drop help handling?
alot of guys that drop want CHEAPPPPP// you get what you payfor
by replasing the 40yo componennts ,balljoints tyrods bushings as well as rear trailarm bushings as well as shock geometry and quality / there will b a noticable improvement in handeling and driving comfort i've used the helwig rear swaybar and it worked great, lots of guys have rear problems by going with a too biig bar// rear bar should b no bigger than 3/4the diameter of the frontbar
09-10-2011, 10:25 AM | #3 |
Active Member
As cdowns said...
To add to that, a drop like you mention may help in the roll area but I didn't notice much difference in 2.5 front and 3.5 inch rear drop in my truck. It's going to be trial and error striking a balance between road stability and comfort since these trucks were primarily made for work. A complete workover of the suspension can be pretty expensive. |
09-10-2011, 11:39 AM | #4 |
The drop in height itself is only going to help so much. Lowering the center-of-gravity makes a difference, but it needs other parts to take full advantage of that lower COG.
Better geometry, better spring rates, shocks designed to compliment, chassis stiffening, modern rubber, & alignment settings to take advantage of everything. If it's handling you truely seek, I would check into the Hotchkis C10 kit. You get all the benefits mentioned in a well designed & engineered kit. It works & is proven. They list the kit as 4/6 drop but that's most likely w/dropped spindles. Substitute stock spindles & see if they have a slightly taller rear spring choice if you need less drop.
09-14-2011, 12:16 PM | #5 | |
SCOTI – Thanks for throwing our name in there! We spent a lot of time making the C-10 truck kit perform awesome! Cjohnson6772 – You can install our parts separately if there are some parts you feel would get you to your performance goal. |
09-10-2011, 03:06 PM | #6 |
Thanks to all of you for weighing in on the issue. I've got a couple of questions for each of you though.
CDowns: The stock front bar is 1.125" if I am not mistaken and I think the Camaro rear bar I have is 0.875". This is close to 75%. Do you think it is worthwhile to install the Camaro bar, or should I just stay away from it? I prefer the Camaro bar to aftermarket bars because it is on the axle and up out of the way. 68gmsee: Did you just use drop spindles and drop springs? Did you get drop shocks as well? I am probably looking for 2" drop springs in the front and 4" drop springs in the rear due to budget. Is there anything else I should be looking for as a must have? SCOTI: I looked at the Hotchkis kit and while it looks like a superb kit I just can't spend anywhere near that amount of money. I'm not looking to race this thing on a track. I am mainly just trying to eliminate body roll under fairly normal (maybe slightly aggressive) driving. Do you think that a moderate drop is enough by itself to appreciate a difference in body roll? Thanks in advance guys. And feel free to weigh in on any of the questions, not just the ones I directed towards you. I really appreciate the advise. I would love to buy one of the awesome pre-engineered kits, but a college kid's fundage just will not allow it. |
09-10-2011, 03:38 PM | #7 | |
09-10-2011, 04:24 PM | #8 | |
Active Member
09-10-2011, 06:50 PM | #9 |
for a 2 1/2" - 4" drop, I'd use a drop spindle in the front with a stock spring. In the back, use a block to get the first 2". then a 2" drop coil, this will help in the ride quality area over a 4" drop spring.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
