09-12-2011, 12:13 AM | #1 |
Petroleum User
What trans and rear are u big blockers running?
I want to put a 454 or 502 in my truck which will be over 500hp. Will a th400 suffice? 4L80? 12 bolt posi rear? Any other suggestions? Can you list what has worked for you in the past, thanks for any input.
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto 2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto |
09-12-2011, 12:35 AM | #2 |
Re: What trans and rear are u big blockers running?
Turbo 400 will be plenty fine, just put some good parts in it.
12bolt should be fine also. |
09-12-2011, 01:14 AM | #3 |
Th400 with 2400 stall and a stock posi truck 12 bolt. As soon as I get the coin together that will be replaced, I don't feel comfortable with that rearend and a 396 with a 177 B&M blower plus a 150 shot of N20. Hopefully we can baby it and not grenade it...
09-12-2011, 01:19 AM | #4 |
I've got a 502, 4L80E and a 9" Strange Engineering rear end.
09-12-2011, 02:18 AM | #5 |
Scrapper 1
well I have a guy that has a 1969 Nova SS with a 427 with 500 HP with a 700R4 with a Gear vender. that can take up to 1000HP from top fuel. witch i doubt any truck in here will ever achieve or ever want to. That much horse power.If your trying to get gas mileage out of your ride and have a big block the 400 will do But you put a gear vender in you can run a regular 12 bolt truck rear end Gear it for the best How i like to say it Full on top end No limit.
So the guy next to you has a 600 HP engine HP is just a little bit of it. you gear it to run Now the 4L80 is a good trans Needs a computer to make it work and most guys that have that set up have a fuel injected motor.Now they top out at 125 145 mile per hour and there pedal is on the floor bored Now Run a 1988 1993 cable 700R4 with the corvette clutches the the metal sprag and run a gear vender. well it just makes that 4L80E cry Cus with the 700R4 with the gear vender with a 4.10 mabey 3.77 gear you have a 8 speed 4 low 4 high first gear off the line with a 410 gear is a 5.90 final gear is like a 2.90 mabey 2.70 Never mess around with that other crap the Gear vender they put them under semi Racing trucks and Drag pull computations.Yes you spend 2500.00 for one but you fall in love with it |
09-12-2011, 02:59 AM | #6 |
Petroleum User
Thanks for the info so far. And, I forgot to mention that my main interest is doing a few burnouts and getting back off it, not top end speed.
09-12-2011, 12:10 PM | #7 |
Turbo 400 for me here be hind a 454
09-12-2011, 03:00 PM | #8 |
"brand new second-hand"
turbo 400 behind a 454 and I put in a 14 bolt with 3:23 gear in back to help with highway rpm's..........it still smokes'em hard!
Steve 69 3/4t custom camper tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c 67 Camaro 96 Impala ss-sold 04 hybrid Honda-saving gas for the blue truck!:b69: |
09-12-2011, 07:44 PM | #9 |
700R4 with 3.08 rear and 31" diameter tires. Still not working out very well, lol. But I am trying!!! :]
09-12-2011, 08:38 PM | #10 |
its all about the +6 inches
stock 402 with a TH400 and a 3.07 12 bolt in the burb
425 caddy with a Th350 and 4.10 Eaton in the longhorn. The TH350 has more clutch material sitting in the pan than I care to see... but I kinda expected it with the shift kit set on full neck snap shifts... and it is hooked to a big block after all. |
09-12-2011, 09:42 PM | #11 |
~Rest In Peace~
tci transmission turbo 400 rebuilt with transbrake ,tci torque converter ,tci cooler and tci deep pan extra 2 qts ,tci shiftmax fluid ,
eaton 4.11 12 bolt narrowed with dutchman axles and disc brakes .4 link coil over
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
09-12-2011, 09:52 PM | #12 | |
To quote Tim Allen ( Tim the" toolman" Taylor) ARRH, ARRH, ARRH!
09-13-2011, 09:27 PM | #13 |
Petroleum User
I went and looked at a 67 today. The truck itself is in bad shape and has the motor and trans gone. But it had a 12 bolt posi in it. Lets assume that it has 200,000+ miles or so. What do u think its worth(just the 12 bolt rear)?
09-14-2011, 07:55 PM | #14 |
I just bought one last weekend for $220. But I don't know if that's good or bad for a well used posi rear.
09-14-2011, 10:45 PM | #15 |
Active Member
T350 with HD clutch packs
3200 stall converter 12 bolt truck with moser axles, eaton posi and richmond 4.10 gears
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree |
09-15-2011, 02:25 AM | #16 |
Fabricate till you "puke"
I ran a 400 turbo behind the 461 inch Olds in my old longhorn, on a 3.42 gear.....was a hell of a ride 5250 on the tach would put her @ 123 mph....& still pullin like a train! I never did break that trans, & it was one that I homebuilt myself......bet she would have been cool as hell with a Vendors on the back tho My sb is backed with a ROD(gotta love that 3rd peddle)...she will cruise all day @ 3150 on the tach(105 mph) on that same 3.42 gear. Yup you gotta love that OD! Its all about gears, it dont matter how big or small.....if you have the proper gearing to keep the motor in its powerband, good things happen....as long as you dont run into "Barney", when you are playin freeway flya crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
09-15-2011, 12:58 PM | #17 |
Devil's in the Details
Mild 454, 4L80E w/ Compushift controller and low stall torque converter, Dana 60 rear w/ 4.11 gears, 33in. tall tires.
Of course, I'm set up more for occasional off road excursions with reasonable highway travel and towing in mind. One thing I love about the Compushift controller is that it lets me set all my shift points, line pressure, shift speed, shift via push-button (or paddle shift), engage tow/haul mode, datalog, etc... Still spins those 33" tires from a dead stop though and runs 2500 rpm at 75 mph.
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread Datsun 240Z, 510 2 door and an old Honda motorcycle |
09-16-2011, 04:12 PM | #18 |
TH400 built to 700hp, internal drum, 2800 stall, +2 pan, etc. with a custom built drive shaft, Spicer U joints, 3:73 Posi. ~29.5" tires. Can't wait to drive it !
09-15-2011, 05:34 AM | #19 |
"THE GREEN GOBLIN"
Im running a 454 with a Th400 12bolt Posi & 373 gears.
Petey-pablo
"THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi Sold Drive it like you stole it! Petey-pablo@sbcglobal.net |
