09-13-2011, 05:42 AM | #1 |
Differnces between 65 and 66 Fleetside?????
Hello All. Been Lurking around her a while. I am the new owner of a 1965 short bed/Fleetside chevy pickup. It Needs some work so I also purchased a 1966 truck as well.
Question: What are the major and minor differences between the 1965 and 1966 fleetside models? I need to know what parts will work and which one will not? also: Stay tuned I will be selling lots of parts that I do not need off of my parts truck. |
09-13-2011, 06:08 AM | #2 | |
Re: Differnces between 65 and 66 Fleetside?????
Howdy and welcome to the forums. A friendly notice... before you start selling parts on this forum, you need to be a paid subscriber... and the ads go in the 'parts board' forum for the 60-66 trucks. It is free to post to ask and answer questions. details on how to become a paid subscriber, if you choose to -W p.s. I answered a few of yer questions on the other forum and sent you some information as well. |
09-13-2011, 07:29 AM | #3 | |
First and foremost . I believe the only major difference (which isn't all that major) between the 65 and 66 is the 66 has back-up lights. Minor differences:
09-13-2011, 10:11 AM | #4 |
1961 crewcab
emergency brake cable routing is different on 66.
All 66 had 2 speed wiper and reverse light, and seat belts. 66 steering wheel is different. 66 has two green lines on the temperature gauge, 65, one. 66 had a 250 cubic inch 6 available, so there is an extra option the kick plate tag. all minor stuff, for interchange purposes.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
09-13-2011, 12:51 PM | #5 |
Great. Thanks for the info. I have seen some back up lights on the 66 and some 66 without. Mine does not have them. Maybe it was a dealer option? Are the Backup lights bolt on or recessed into the fender? (can't tell from the pictures)
Anyone know where I can purchase a data plate online? Mine is missing. What should the Data plate look like? I have seen a few examples-just want to make sure I get the correct one. Not sure why GM would put the VIN #'s on something that could be so easily removed/rust out or Fall off? My 66 Mustang has them stamped into the Fender Apron. |
09-13-2011, 02:35 PM | #6 |
They are recessed.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
09-13-2011, 07:51 PM | #7 |
Easy Does It
These trucks Vin tags are located along the driver door opening, the 5th digit will tell you the year 5 for 65' 6 for 66' C14 short bed C15 long bed.and a tag along the kick panel inside where you left foot would be, tells the weight and color options ect... basically all the parts to be concerned about interchange from 1964-66 -order a LMC truck cataloge thats a good refrence and shows diagrams of parts and a vin decoder.
09-13-2011, 09:11 PM | #8 | |
John |
09-13-2011, 01:06 PM | #9 |
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
09-13-2011, 09:30 PM | #10 |
VIN should also be stamped into the front driver side frame rail (and one other less easy to see spot that I forget...) But if you lean in over the driver front fender and lok down, the number should be stamped (readable in that orientation) along the top of the c-channel of the frame rail. Good way to confirm if you have the original cab/chassis combo.
09-13-2011, 11:42 PM | #11 |
About one year.
