Old 09-13-2011, 12:24 PM   #1
68C10HotRod
68C10HotRod's Avatar
Parting out a 292 6cyl
I'm parting out the original 292 that came in my 68 C10.
motor stands $20 & mounts $10
intake manifold $10
exhaust manifold - 1 stud broke $10
heat riser $10
complete 1bbl air cleaner $20
fuel pump - 1+ year old $10
starter $20
any other parts on request (valve cover, side covers, etc)
all prices are + shipping to your zip.
Bryan
'52 Bel Air 2dr HT - in pieces
'68 C10 - 6cyl/4spd REMOVED, LT1/T56 to be installed
Any society that would give up a little liberty to gain a little security will deserve neither and lose both.” - Benjamin Franklin
"And those who know what's best for us, Must rise and save us from ourselves" - RUSH lyric (mockery)
68C10HotRod is offline   Reply With Quote
Old 09-13-2011, 01:27 PM   #2
68 IRON
68 IRON's Avatar
Re: Parting out a 292 6cyl
Interested in the intake and exhaust manifolds. Could you post pics of whats broken on the exhaust? If you can give me a rough estimate for shipping, that would be great! Go Huskers....pound those dogs! Sorry, my zip is 98501.
68 IRON is offline   Reply With Quote
Old 09-13-2011, 02:07 PM   #3
mahanian
C10 addict
mahanian's Avatar
Could you give me a shipping quote for the complete air cleaner to zip code 85224? It includes everything in that picture, correct?
Put me in line for the manifolds as well.
Could you post a picture of the valve cover? Any dents in it?
Was the 292 bolted to a 4 speed manual? If so, do you have the flywheel?
Did the truck have power steering? If so, how much for the complete setup?
Where does the heat riser mount? The 292 in my 67 doesn't have that.
Jared
67 C10 CST Short Fleet Big Window
65 C10 Custom Short Fleet Big Window
67 Camaro RS
mahanian is offline   Reply With Quote
Old 09-13-2011, 03:15 PM   #4
TheSeeker
Darn he beat me to the punch, if the truck had PS or AC and you want to sell. Let me know!
TheSeeker is offline   Reply With Quote
Old 09-13-2011, 05:52 PM   #5
68C10HotRod
68 Iron: Looks like about $57 total. See the pic with the shiny broken bolt. It's where you tighten down the exhaust pipe.
mahanian: I'll have to get the box from storage tonight as it's not a my house. Yes, all parts in that pic will be there. The separate heat riser goes on the exhaust manifold & sends heat up that 90deg tube w/45deg bends in the breather picture. You'll want it with the air cleaner parts if it's not already on your truck. Motor NOT pulled yet but should be soon. I will make a new post for more of those parts so keep an eye out. Have all the linkage needed too.
Heatriser installed on exhaust manifold
Heatriser moved down & back toward firewall
Seeker: NO AC or PS. Wish it did cuz the PS brackets alone are worth coin IF you can ever find them. Good luck on your search.
Bryan
Old 09-13-2011, 05:56 PM   #6
68C10HotRod
Here's a couple of general motor pics & mahanian can see the valve cover - it is perfectly straight, no dents or dings at all. Even has the clips still attached.
Bryan
Old 09-13-2011, 07:06 PM   #7
mahanian
C10 addict
mahanian's Avatar
Bryan,
Could you give me a package price including shipping for the following items:
air cleaner
both manifolds (if 68 IRON passes and no visible cracks)
valve cover
heat riser
three groove crank pulley
Jared
67 Camaro RS
Old 09-14-2011, 10:04 AM   #8
LockDoc
The Older Generation
LockDoc's Avatar
Brian,
I will take all of the motor mount parts pending shipping cost. Hopefully they will fit in a USPS Priority Mail flat rate box if disassembled. Thanks. Zip: 50171
LockDoc
Leon
Old 09-18-2011, 06:04 PM   #9
68C10HotRod
Originally Posted by LockDoc View Post
Brian,
LockDoc
Leon,
Worst case would be the Large box USPS for $15 or they might fit in the Medium box for $11. They should lay down & fit within the 5.5" box size. The only problem is the motor is still setting on them today & I don't have either of those boxes yet. I'm working to remove the motor & will get boxes tomorrow. So $41-45 total depending on which box they'll fit in.
Thanks for the poke btw.
Bryan
Old 09-18-2011, 10:17 PM   #10
LockDoc
LockDoc's Avatar
Originally Posted by 68C10HotRod View Post
Leon,
No problem on the poke..... & I'm in no hurry on the mounts. Just let me know when you have them out and get a firm price and I will forward the funds... Thanks.
LockDoc
Leon
Old 09-30-2011, 07:13 PM   #11
68C10HotRod
LockDoc
Hey Leon,
Guess what that is? All the motor mount parts in a Medium Rate box. If you don't mind the rounding up .05, just make it $41. I'll send you a PM with my paypal addy.
BTW, anyone who says it's no big deal to remove a 6cyl/4spd together with the Cab on the frame, should have come over to help. 12 rivets later - 2 that are virtually impossible to grind off, to remove the tranny xmember - BIG HASSLE. Just glad I got an air chisel & die grinders.
Also, Mahanian -
Did you get all your stuff in good condition? Never heard from you & just wanted to make sure it was all good.
Thanks guys!
Bryan
Old 09-18-2011, 05:54 PM   #12
68C10HotRod
Originally Posted by mahanian View Post
Bryan,
air cleaner
valve cover
heat riser
Jared,
Sorry for the delay. Pulley was a hassle to remove but off now. All those parts for $90. I can box up the manifolds, heat riser & valve cover together in 1 box (39#) for $34 shipped UPS. Pulley, all bolts & cleaner parts in another (23#) for $23 UPS. Total is $147. The length of the exhaust manifold & valve cover forced me to split the stuff up. I can ship them out Monday if we can settle up before morning. BTW, I saw NO cracks or flaws in either manifold.
Thanks for waiting.
Bryan
Old 09-15-2011, 01:05 PM   #13
70STOVEBOLT
70STOVEBOLT's Avatar
Put me in line for the exhaust manifold and valve cover. If they get to me I WILL TAKE THEM.
Thanks,
Mark
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 09-16-2011, 10:40 AM   #14
68 IRON
68 IRON's Avatar
HotRod, I'm gonna pass on the two manifolds. Local parts became available thanks.......nice parts and price!
-John
Old 09-18-2011, 06:07 PM   #15
68C10HotRod
Thanks,
Mark
They will be easy to ship if Mahanian passes on them since I had to split them up. Will let you know asap.
Bryan
Old 09-18-2011, 09:16 PM   #16
mahanian
C10 addict
mahanian's Avatar
Hey Bryan, I'll take them, please send me your paypal email and I'll send you the payment tonight.
Thanks!
Jared
67 Camaro RS
Old 09-19-2011, 06:18 PM   #17
68C10HotRod
Thanks!
Jared,
Both packages shipped out today. Put your email on the notifications so you should get track #s when shipped. Thanks & good luck with your 292 project. I REALLY liked mine until it finally quit. Can't believe how hard (good way) it ran considering it was pretty much a 5 cylinder since #2 had almost no compression. Good old torque monster motor but just not worth it for me to rebuild since I had a low mileage LT1/T56 that needed a home. Would have been interesting to run a small 4bbl & intake along with split exhaust manifolds & duals. Mine only got about 8 mpg (BBC kind of mileage ).
Bryan
