Corina Patina 65 low rider
Well here we go again, we pulled the baby blue 65 C10 in the shop, removed the running boards, cut the bed bolts loose so we could remove the bed and wouldn't you know it some enterprising farmer had tack welded the bed crossmembers to the frame stancions on the rh side. so we could not set the bed on the ground.......oh well will send pictures tomorrow.
![]() Kieth ![]() ![]() |
Re: Corina Patina 65 low rider
Subscribed. I like your style.
Thanks Scot, here are the pictures:
Backin it in: http://kieth.smugmug.com/Trucks/65-C..._fg2LMwh-XL-LB A lwb fleetside will fit in the shop: http://kieth.smugmug.com/Trucks/65-C..._CXhFn49-XL-LB Got the running boards off: http://kieth.smugmug.com/Trucks/65-C...2_zCRJTN2-L-LB Bed is a little worse for wear, cut the bolts and the PO had welded the front 2 bed crossmembers to the frame brackets. http://kieth.smugmug.com/Trucks/65-C...8_3QTSPxZ-A-LB Oh well here we go again.............Kieth |
I like it! Reminds me of my 66 when I first got it.
Stuck a battery in , put some gas in the carb and Corina fired right up. Now we may just leave the 6 banger in her....if it is good. Got the bridge kit in, laid it out, getting ready to start welding her in.
Step 1. move the center crossmember back 1.5" for fenderwell clearance. step 2. remove coil springs, shocks, panhard rod. step 3. weld in the first part of the bridge here are some pictures: She started on the first lick...... Laid out the bridge kit will get started tomorrow on installing it. Kieth |
VA72C10
![]() Join Date: Mar 2008
Looking forward to the build!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
![]() Join Date: May 2009
Hi Keith will looking forward to this build I'm subscribed, what size is the I6?...Vernski
#8 | |
It is just a 230, I found a nv3500 for it (5 speed OD) but do not know if it will pull the OD or not, worst case we will try it if the engine does not have enough umph I have a 250 I6 -- wish I had a 292 but oh well or could find a 350 to put in it, I am trying to really do this build on a strict budget so am trying to purchase very few items.......Kieth |
![]() Join Date: Mar 2011
I liked your last build and I'm looking forward to what you do to this one. Subscribed.
Kieth,
I have a buddy (named Keith ![]() ![]() |
Registered Loser
Nice! Should be a cool project.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
#12 | |
My mom was only 17 when I was born, she was under sedation when they asked her to spell Kieth, she got it wrong, but it is that way on my birth certificate. When I went to 1st grade the teacher sent a note home telling her that I was spelling my name incorrectly. She sent a note bac telling her that I could spell my name XYZ if we wanted and it was none of her D.... business , so the spelling stuck. I use it on all forums because no one else spells it that way. Thanks for the heads up on the NV3500.....I just need to figure out the hydraulic clutch issues which I think are easier than the issues with the T5 and we will be ready to make the change. Kieth (I figured for $250.00 it would be hard to beat.) Started removing crossmembers, checking the layout, etc......one thing we are doing a little different is making sure we move the rear end back 1.5" so the larger diameter tires and wheels will clear the lip of the fenderwell. We are experimenting with ways to do this easily so I can make those changes to my 66 gmc with as few surprises as possible. Last edited by kieth; 09-28-2011 at 09:02 AM. |
Here are pictures of the initial layout, went and read the directions first that does make things a little easier....I hope !
Clamping in place for trial fit. Checking it for proper position. Bracing to hold it all in place when we remove the crossmembers. Grinding rivets lots of work, and we lowered the axle so it touches the frame to check for the center point of the suspension as it rotates through it range of motion. first time for this stuff hope all goes well ![]() |
Kieth - I've had similar issues with my name "Scot". I tell folks it was because the hospital I was born in charged by the letter on the birth certificate. My parents didn't have much money back then, so with the hospital bills and all - they could only afford one "T" for my first name and had to change the spelling of my middle name from "Allen" to "Alan".
Quite sad. ![]() ![]() |
#15 |
got some more done today, got interupted quite a bit, oh a few hints to those who try and do this, the 4 main bridge pieces have a front and back and a left and right set, the front leg is shorter since that part of the frame is higher, the back set of legs are longer since the frame dives away.
My idea for moving the rear axle back has been put on hold, the bridges would not properly line up so we moved them to the standard axle position. We well try and move the axle back after the bridge is installed, it looks to have enough clearance to go bact 1 to 1.5" will let you know. This is what we did as we went along: Trial fit to see what has to be removed: Startd to remove rivets, welded a cross brace in for support. Started clean up and made notches where bridges sit notches ready for tack welding and fit up Last edited by kieth; 09-28-2011 at 06:19 PM. |
#16 |
continued down the road to slam Corina today, We finally figured out a lot of things, made some mistakes, corrected them , and finally got everything leveled, square, and tacked in place. Hooked Corina up and took her over to the welding shop (sometimes you just have to know your limits)
Here are the pictures. 10. More grinding 11. We finally gave up and just tacked the darn things together, way too much drama trying to figure out how to tack it on the truck. You never had anything that was square as a referece, we finally layed everything out on a soldid bench and tacked the bridges together. Here is the Passenger side trial fit. we did way too much trial fit 12. Passenger side inside leg low shot on how it say on the frame. 13. Passenger side inside leg full shot. 14. checking both sides for position in relation to the center of the axle and for level. We finally figured out that by having the bridge tacked we could square the bridge to the outside of the frame, make sure it was centered on the axle and check it across to the other bridge to make sure they were level and square. It worked (we were lucky the frame was sitting on jack stands and the frame itself was level across the top, so we worked everything in relation to that and the outside of the frame , let the inner legs sit where they may because it did not matter...... |
#17 |
Here are some more pictures:
15. Drivers side bridge being cajoled into final position for tacking. we tacked it right after this but I did not have enough hands to read the square, the lever, and the camera. 16. Checking for level befor final front height adjustment: 17. Level after final adjustment and tacking into position. Square with the outside of the frame----same height side to side---in the front and the rear. I love it when a plan comes together, now I just hope it goes down the road straight when the welded gets finished....... ![]() |
#18 |
Great start! Sub.
I Saw Elvis at 1000 Feet - John Force |
#19 |
VA72C10
Nice progress!
#20 |
Nice job.
#21 |
Just a little update, got the bridges installed:
Blocked it up to what will later be a normal ride height, but that will change since we are installing a 2" spaced betweet the rear end and the trailing arm. Mocking up the new Holland panhard rod and the air bags. The parhard bar was only $30.00 think I will have to look for some more tractor parts for Corina. what do you think of my wheels $9.00 each........I had the tires |
#22 |
VA72C10
Looking good! Good deal on such a nice panhard bar!!! SO is it new and intended for tractors? The cheap adjustable ones are normally 40-60 for our trucks so this is an alternative...how long is it (shortest and longest it can go)?
And SUPER deal on the rims!
#23 |
Local Redneck Authority
Hey there, nice rod... I used the same idea on my bike.
-Kevin four on the floor feel the beat in your soul movin to the rhythym pumpin til ya cant take no more dance if you want to do what you came to you cant ignore the feeling of that four on the floor |
#24 |
#25 |
Have not updated in a while, Corina is progressing slowly, here are a few pictures,
Installed the 5 x 5 rear axles, put the cragars on so we could make sure the airbags and other suspension components would clear. Installed 2 x 2 spacer blocks for the rear end removed the front trailing arm brackets, made spacers to move them back 1.5: and turned them upside down. getting ready to install them with new bushings...will update later....Kieth |
