09-14-2011, 07:34 PM | #1 |
Will this fit my 72 C20?
There's a guy here locally parting out a 74 1/2 ton cheyenne longbed with a 3:73 12 bolt rear, looks like 5 lug all the way around.
IF this fits, it sounds like the easiest way to swap out my front crossmember and rear for 1/2 ton stuff. |
09-15-2011, 12:56 AM | #2 |
Re: Will this fit my 72 C20?
Anything can fit with time a welder and some ingenuity.... The rear end you can swap but you may have to make some suspension mounting mods which are easily done... are you talking replacing the entire crossmember system and welding in the 74 crossmember then yeah it will work, if not can you give more specifics of what you have in mind.
09-15-2011, 10:12 AM | #3 |
Replacing the entire crossmember, aren't those bolt in? Maybe a hole modification or three?
72 C20 http://www.houseofdewm.com Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=485286 |
