Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 09-14-2011, 11:15 PM   #1
tow guys
tow guys's Avatar
Looking for air filter for compressor
I have an 80 gal. 2 stage machine from Atlas that works like a dream. The problem I'm having is with water in the lines. Seems after the machine cycles a couple of times, it creates water in the lines due to the increase in temperature. I do alot of media blasting, da sanding and continues use that causes the machine to heat up the top of the tank. I also plan to tackle painting my project pretty soon and water in the lines will not do.
What are my best options to remove unwanted particulates and water for blasting and painting.
Check out my 70 GMC tow truck project here.......http://67-72chevytrucks.com/vboard/s...d.php?t=440431
Member of the 1-Ton Club!
http://www.eastcoastcarandtruck.org
tow guys is offline   Reply With Quote
Old 09-15-2011, 08:41 PM   #2
Hurst28
Re: Looking for air filter for compressor
These work well and replacement filters are cheap. desiccant filters work well too.
http://www.tooltopia.com/motorguard-m60-2.aspx
Hurst28 is offline   Reply With Quote
Old 09-17-2011, 08:52 PM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
When you install a filter,put a drop leg with an automatic drain in before the filter.It will help keep the air dry and clean and make the filter last much longer.You could also use an air line sryer but I doubt you can afford to buy or run one.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 04-21-2012, 06:28 PM   #4
brans72
What brand automatic drain do you guy's recommend?
brans72 is offline   Reply With Quote
Old 05-04-2012, 04:24 PM   #5
ETsC10
Hand Crafted C-10
ETsC10's Avatar
brans72,
Please ask your question HERE.
Thank you.
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
