made in america
got me a t-5!
bought me a t-5 last night!
![]() my wife just gave me a weird look when i told her so i figured id let yall know.
2005 gmc sierra- 4/6, t56, cammed 5.3. 4.10, big bars, and brakes. sounds good 1964 c10-283 powerpack, 3 on the tree ![]() 2004 corvette- lowered, borla, tuned. slow ![]() my old girl 1966 c10- 305v8, t-5 sold |
Hell yeah!!!
Re: got me a t-5!
Best upgrade ever!
Stock is good but custom is the sh*t! |
![]() Join Date: Oct 2009
Re: got me a t-5!
COOL! I think you'll be very happy with it!
made in america
Re: got me a t-5!
thanks to you ill actually be able to hook it up to the rest of the truck!
Re: got me a t-5!
Ha! I'm happy to be back home - if I can get my brakes done, maybe I can then do more than a t5 test drive! I'm itchin for a cross country. But I"ll actually drive around the block about 20 times to make sure everything is workin right... Sing out if any questions pop up, lotsa folks on here have done this swap and helped me a lot when I did mine.
made in america
Re: got me a t-5!
wildo!
Re: got me a t-5!
yes jocko,i read your thread on the t5 swap,excellent info!thanks for that,it will certainly help a lot of us on here!by the way how much did you have to shorten your driveshaft?
#8 | |
Re: got me a t-5!
Sorry I missed your d/s question from earlier - ended up taking about 8" out of it just to give you a rough estimate - but you'll need to measure your truck exactly to have the shop cut it correctly. Make sure you measure with weight-on-wheels, not on jacks. Most shops want the measurement from the vertical face of the rear of the tailshaft housing (i.e. the rear seal) to the centerline of the rear u-joint (i.e. in most cases, if you have the driveshaft out - it's the surface of the half-cradle where the u-joints rest). |
Re: got me a t-5!
My T5 is holding up nicely (for now) behind my 350.
0.72 OD and the 3.27 rear end makes for 1700 rpm @ 60. ![]() |
made in america
Re: got me a t-5!
scot i didnt know you had a t-5. i musta missed that in the build somewhere. i guess it will be just fine behind my stock 250!
i wish i knew what my t-5s overdrive was. the tag with the info that actually matters is completely gone. it caint be any worse that 1.1!
Re: got me a t-5!
66rw, u can measure your o/d by placing the shifter in 5th and estimating the amount of tailshaft rotation relative to one full rotation of the i/p shaft. o/p shaft should move around 3/4 of a rotation if it's a .76 ratio or if it's kinda between 3/4's of a rotation and 1 full rotation - it's probably the .86 5th gear ratio. Those were the 2 common o/d ratios in S10s - but others were available in other (non-S10) transmissions. I was lucky with a a .73 o/d.
made in america
Re: got me a t-5!
thats good info jocko! i must say thou. i ended up locating the good tag. i have 1352 192. here in a second ill look it up to see what she has.
and i know how yall are. everything is better with pics!! ![]() ![]() ![]()
Re: got me a t-5!
1352-192 GM 1989 S-Truck 2.8L V6 Only R 3.70 3.97 2.34 1.48 1.00 0.79
made in america
Re: got me a t-5!
i was just about to say that.
thanks scott!!
#15 |
Re: got me a t-5!
will my manual trans linkage out of my 64 gmc work on a t5 or does it need modifications?
some one mentioned a t5 swap thread can someone pose a link to it? |
#16 |
Re: got me a t-5!
t5 has no linkage associated with it at all - it has an internal rail shifter (so just the stick pokes thru the floor) - so if you do the swap, all your old linkage goes in the closet, on ebay, or in the circular file - it's kinda nice! Here's the mentioned thread - http://67-72chevytrucks.com/vboard/s...d.php?t=482069
66redwhite - that's some future hot rodder ya got there! He looks as excited as we all sound! |
#17 | |
Re: got me a t-5!
#18 |
made in america
Re: got me a t-5!
yeah he loves trucks just as much if not more than i do. hes always tellin me that the lower the truck is the faster it gets. lol. he caint wait to jam gears of his own. and much like his dad, he has decided on an s10 for his first truck. well most days...
#19 |
made in america
Re: got me a t-5!
you use your original bell houseing. so the clutch linkage does not change
#20 |
Re: got me a t-5!
Unless you want it to.
![]() ![]() In hindsight, going with some cheap block-hugger headers or rams horns would've let me use the stock linkage AND kept me away from some steering issues. ![]() ![]() |
#21 |
Re: got me a t-5!
[QUOTE=Scot_Douglas;4903808]Unless you want it to.
![]() What kind of setup is that Scot? interesting. |
#22 |
Re: got me a t-5!
Homemade bracket, shortened clutch arm and a hydraulic pull slave cylinder.
#23 |
Re: got me a t-5!
ya, i don't have my stock bell housing, i bought the truck engine less,
it does have the clutch pedal, so if i want to use a camaro t5 bell housing am i just better off using a hydraulic clutch setup? |
#24 |
Re: got me a t-5!
truck bell housings are a dime a dozen - I'd buy on of them from a junkyard. If your truck has a clutch pedal - and you mentioned above your truck had stock clutch linkage (sorry, thought you meant shifter linkage earlier!) s0 I'd just grab a bell housing and go. You'll want to make sure it has an opening of about 4.686", which most do (i.e. don't buy the one that is larger than 5", then you'll need an additional adapter).
That's the cheapest approach - and you have to have a bell housing anyway (i.e. you bought it engine-less, so assuming it was bell-less also?) This way, you can use stock pedal, clutch linkage, (bell), etc etc. I'd look for a bell that has the access panel on bottom, not a solid aluminum (scatter-shield-like) one to help make the install easier. Hy clutches are NOT cheap, and they are (in my experience) finicky to bleed, etc. But then again, i don't even like bleeding brakes.... ![]() |
#25 |
Re: got me a t-5!
wow - that's cool. Is it an up and running system or still just in the build phase? I've never seen such a thing! Probably easily adjustable. Nice! Looks like it makes lotsa room for those headers!
