04-12-2003, 12:15 AM | #1 |
Bottoms Up
I wanting to position my cab so I can do some clean up and blasting on the underside. Is it ok to lay a bare cab on its back? I know most of the weight seems to be in the front end of the cab and I wasn't sure if it could distort the cab by laying it down. Anyone have any experience with this? Thanks....Stroker
72 SWB parts and pieces Oklahoma |
04-12-2003, 12:49 AM | #2 |
cab flip
I just did mine . The seat was out so all I did was bolt a 4x4 post across the floor all the way across the cab using the front bolt holes for the seat (4 holes). The 4x4 has to be pretty long . Then use saw horses on each side to hold it up . Then the cab will rotate forward or back but be careful because the cab is top heavy & will flip easily . The bolts should be about 5-6 inches & grade 5 or use a steel bar instead of a 4x4 . Also I thought of using a 4-6 " piece of foam ! Good luck !!
04-12-2003, 02:37 AM | #3 |
Recovering Truck Driver
I had mine laying on it's back a few times before I put it on the truck, everything fit together nice.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
04-12-2003, 03:07 AM | #4 |
now thats a true COON DOG
Nope as long as your real gental laying it down, and you don't put any extra weight on it while it's on it's back then you should be fine....
current project 67 402BB stout th350 3.08's with a locker. Plan on tubs 18.5's out back! (thanks Burnsman!) 71 SWB Stepside, was a 250, now is a 402 Big Block with 4 speed and 3.73's ( was crushed by a tree, bed sold, motor pulled) was my first truck!... oh well... 72 LWB 4x4 350 4-speed 3.08's posi wearing army olive drab green (SOLD!) 68 BURB 50TH LOOKALIKE work in progress, soon to have 250-I6 with a 3-speed on the tree 4.11's and posi ( currently sitting in back yard tarped awaiting time, $$$, and lots of love!) 67 1 TON- work truck 396 sm 420 4-speed, flat bed 4.57 gears "big red" (my first landscape truck, very rusty and crusty! but still gets the job done when needed!) |
04-12-2003, 08:16 AM | #5 |
We lay them on their back on a piece of 4" foam all the time with no problems.
Rest in Peace Ed. Thanks for all the good times. |
04-12-2003, 11:41 AM | #6 |
Thanks for all the info guys..Stroker
04-12-2003, 01:06 PM | #7 |
Seņor Member
They also balance pretty well when tipped up onto the firewall. Mine has spent lots of time in this position and on its back. If you've got good paint and/or a rough floor, throw down a blanket or a big piece of foam and you'll be all set.
