09-20-2011, 01:14 AM | #1 |
Seat upholstery
I am trying to reupholster my seats, I have them all torn down, and cleaned the frame and springs, painted them. Just about every parts company sells a seat cover, but no one seems to have the foam, or the other stuff, what is that, burlap in there?
I assume that most people just hog-ring it all back together, but i was hoping to keep it stock, does anyone have an assembly manual for the original? Thanks! |
09-20-2011, 11:39 AM | #2 | |
Re: Seat upholstery
hog rings can also be used to tie the springs together. what i do is use the wire ties that come with trash bags first, that way I don't waste a bunch of hog rings if something isn't the way I like. when It looks good I go back and hog ring it. it you have any weak springs stuff cottin in them do the same on both ends driver and passenger sides because those springs get the hardest use. Hope this helps Mark |
09-20-2011, 11:58 AM | #3 |
Re: Seat upholstery
Or to bolster the sides you can just put in a bunch of 2x4's and plywood like my original seat had when it was reupholtered. You might consider adding a layer of memory foam to soften it up a bit make getting it smooth easier.
09-20-2011, 01:57 PM | #4 |
Re: Seat upholstery
Orrie do you have any pics of that? I would like to see that.
09-20-2011, 07:49 PM | #5 |
Re: Seat upholstery
I might on the disassembly tape I still need to tranfer from an old camcorder. I sold the seat a while ago.
09-22-2011, 12:15 AM | #6 | |
Re: Seat upholstery
Thanks Mark, So burlap down the springs, and then get a sheet of foam, and cover it. How thick of foam did you use? How much trimming did you do to contour it? |
09-22-2011, 12:24 AM | #7 |
Re: Seat upholstery
if you need anymore help with your seat shoot me a PM I own an upholstery shop and I could probably point you in the right direction.
09-22-2011, 10:16 AM | #8 | |
Re: Seat upholstery
tackcharlotte Correct or help with my explanation if i am wrong. I am teaching myself upholstery. |
09-22-2011, 05:25 AM | #9 |
Re: Seat upholstery
I've seen foam at places like Fred Meyers, and hardware stores.
