Old 09-22-2011, 03:34 AM   #1
Hazieview
Building Dreams out of Dimes!
Is anyone running a 1 ton 4x4 dually?
Hey guys I'm currently looking at a 1 ton single cab 4x4 dually.
I currently have a single cab 2wd half ton fleetside. So that is all I can compare to. Figured I would ask someone that actually has a 1 ton.
How would the ride be on the 1 ton single cab 4x4 dually?
Would a sb400 be enough to get it down the road and haul trailers with?
Thanks!
(Trying to get away from the hot rod style truck and more to a work truck.)
1981 Chevy short/wide.
SB400 350th
Hazieview is offline   Reply With Quote
Old 09-22-2011, 06:39 AM   #2
GM72K10
Next!
GM72K10's Avatar
Re: Is anyone running a 1 ton 4x4 dually?
I have a 350 in mine and it will plow snow, haul at least 2 tons of material and it rides well for a "big" truck. all in stock condition. Buy it!
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 09-22-2011, 06:44 AM   #3
Hazieview
Thanks for the feedback! I still got to work out a few things but I'm leaning towards buying it.
SB400 350th
Old 09-22-2011, 07:45 AM   #4
BigBlocksRule
How will it ride?
Like an iron-wheeled wagon.
What will it pull/haul?
Anything you want.
They're a truck and ride like one. But they're some damned hard workin' trucks.
It probably has 4.11 cogs, won't be much for highway use.
What year? '87 - '88 are TBI and can run the 4L80E with a wiring harness update.
If it doesn't already have 'em, add headers. They're the biggest bang for the buck, hot rod or work truck.
BigBlocksRule is offline   Reply With Quote
Old 09-22-2011, 08:49 AM   #5
Hazieview
The truck is an '81. I will be putting a '76 SB400 in it. (With headers!)
SB400 350th
Old 09-22-2011, 09:27 AM   #6
I have a 76 1 ton dually with a 496 I just put in it. I love the thing, rough riding ? Yes. But who cares that motor should be OK but it will be working it's ass off.
Old 09-22-2011, 09:47 AM   #7
Hazieview
Well it looks like all the guys that do have 1 tons really love them. So would the SB400 be unempresive? My SB400 should be making around 550 lbs of torque... Is that not enough?
Are there any tricks to giving the 1 tons a better ride?
I don't really need a 1 ton, I just love this truck. Different leaf springs maybe?
SB400 350th
Old 09-22-2011, 09:50 AM   #8
BigBlocksRule
SB400 will be a hoss, swap to Vortec heads if you have the chance. Make sure you have a good radiator and water pump and it'll be fine.
I'm building a 489 for my '97 CC dually 4X4, sure looking forward to it. May end up with a turbo down the road...
Old 09-22-2011, 12:02 PM   #9
jitteryguy
GoatLube Experss
jitteryguy's Avatar
both of mine rides decent for a 1 ton, mine are both crewcab's so I got a little more wheel base, that helps some.
if you want it to ride like a half ton, air bag it. with the right set up it will haul more wheight and ride good .
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 09-22-2011, 07:50 PM   #10
nutsforchevys
nutsforchevys's Avatar
Rough riding, bad gas mileage, pull like a son of a gun.
72 Super Cheyenne lwb 4X4 Ocra / White
88 Chevy 1 ton Dumptruck
88 Chevy 1ton Flat bed 4X4 white
nutsforchevys is offline   Reply With Quote
Old 09-22-2011, 10:44 PM   #11
Hazieview
I got some after market heads on it (not vortecs, they are dart heads) and I got a Be Cool stock replacement aluminum radiator with dual electric fans. So I hope that's enough
One more question....
Crew cab or single cab..? Big weight difference or no?
SB400 350th
Old 09-22-2011, 11:13 PM   #12
bmchevy1979
bmchevy1979's Avatar
If that 400sb is putting out 500+ ft lbs of torque it would be about even with a factory big block with a mild cam so I think it would be just fine a lot of 1 ton trucks in my area have completely stock sb350s and do just fine
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 09-22-2011, 08:14 PM   #13
BigBlocksRule
I'm doing a '97 crewcab dually 4x4, lowering it about 3", losing the bottom fat overload leaf and adding helper bags. I'm figuring it'll ride like a heavy half, pull like hell with the port injected 489!
Old 09-22-2011, 08:29 PM   #14
79k30dually
My 1 ton is a 79, 4x4, dually, dana 60 3.73 traclok front, dana 70 3.73 powerlok rear, 454 tbi, 465, 205. I don't piss blood when finish driving it, BUT when I hook to SERIOUS loads, WE may stop moving, BUT the wheels DON'T stop SMOKING. If you're serious about not owning a "boy" truck, 1 ton speaks for it self. Ron
sorry for quality, Ron
79k30dually is offline   Reply With Quote
Old 09-22-2011, 10:05 PM   #15
GM72K10
Next!
GM72K10's Avatar
Cab and Chassis diesel dually 4x4s are good too!
86 K30 CUCV M1028A1
Old 09-23-2011, 02:59 AM   #16
BigBlocksRule
Sounds a lot like the 406 I'm building for my '77 K-5 with Bowtie Vortec heads. You'll have more power than most stock big block trucks, better mileage, too.
Old 09-24-2011, 09:36 PM   #17
overloaded
overloaded's Avatar
I'll probably jinx myself, but we're currently looking at a 79 K30 3+3 4x4 dually (that's a lot of alphanumerics!) with 454, 4 speed and 4.56 gears as the new tow rig.
It would just about be the perfect all around truck, except for parking at the mall.
Will post pics if it works out. My only concern is the 4.56s...that's a lot of gear for the highway!
overloaded is offline   Reply With Quote
Old 09-25-2011, 12:57 AM   #18
Hazieview
Only thing I worry about at the mall is door dings. Kind of the reason I want a flat bed. I little harder to tear up.
SB400 350th
Old 09-25-2011, 01:00 AM   #19
Hazieview
I'm thinking the same thing. Perfect truck that I can actually use as a truck! I have a half ton but I want a truck that will be ready for any job when I'm ready to put my truck to work. A half ton has its limits.
I do have the same worry about the low gears on the highway not really for fuel mileage but more so for the wear on the engine and trani from being at such s high rpm. I have an impala for fuel mileage...
SB400 350th
Old 09-24-2011, 10:44 PM   #20
BigBlocksRule
Parking at the mall is no trouble.
Just plan on a loooong walk.
Old 09-25-2011, 01:06 AM   #21
Prerunner1982
Prerunner1982's Avatar
Not mine, but thought I would contribute a picture.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 09-25-2011, 07:48 AM   #22
GM72K10
Next!
GM72K10's Avatar
Military duallys M1028a2s with 205s, and they ARE mine, for now anyway.
86 K30 CUCV M1028A1
Old 09-25-2011, 09:48 AM   #23
overloaded
overloaded's Avatar
Single cab, plain jane duallys look so tough! They're just all business
Old 08-21-2015, 09:11 PM   #24
1988 1 ton
1988 1 ton's Avatar
I have a 1988 chevy 4x4 1 ton duallly. 6.2 gets around pretty good.http://67-72chevytrucks.com/vboard/i...lies/chevy.gif
1988 1 ton is offline   Reply With Quote
Old 08-21-2015, 09:14 PM   #25
rs74
rs74's Avatar
There are a couple of other K30 threads on here.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
