Old 09-24-2011, 12:21 AM   #1
Ackattack
Ackattack's Avatar
Pitman arm question
I got a new power steering gear box and pitman arm for my 69 (no-buck). It has 73+ upper and lower control arms on it. I got the whole front suspension from a donor 72 suburban that obviously had been swapped in there as well. So I don't know what is what. The partnumber that I removed is 6272424.
So tonight I got to put in my new pitman arm and gearbox. Well come to find out the pitman arm that I installed (ordered it for a 73 C-10) is shorter than the one I removed. The partnumber that I removed is 6272424.
Now, when I steer all the way to the left, the spindle doesn't quite hit the stop. Turning right it does. Looking around at stuff it looks like the tie rods could be adjusted so that the left spindle would hit the stop, but I didn't want to mess up my alignment. But having the shorter pitman arm, is it already messed up?
Should I install a 72 pitman arm, or just stay with the 73? What do y'all think?
Ackattack is offline   Reply With Quote
Old 09-24-2011, 10:11 AM   #2
turp mcspray
turp mcspray's Avatar
Re: Pitman arm question
The shorter arm will just make the ratio faster.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 09-24-2011, 05:37 PM   #3
OhOneWS6
OhOneWS6's Avatar
That is backwards. The shorter arm decreases the travel distance and will make the ratio slower. You need the longer pitman for a 72. It should resolve your problem.
OhOneWS6 is offline   Reply With Quote
Old 09-25-2011, 07:39 PM   #4
Ackattack
Ackattack's Avatar
well I bit the bullet and got another new pitman arm for a 72. Looks like it will work fine and I'm back in business.
Old 01-22-2012, 11:05 PM   #5
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
So the 72 pitman arm is longer than the 73 and yet the 72 arm fits the 73 box?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 03-22-2012, 01:23 AM   #6
LostMy65
LostMy65's Avatar
Anyone?
Old 03-22-2012, 11:13 AM   #7
OldCreek
OldCreek's Avatar
That appears to be true. I bought a 72 pitman and it fits the 80's steering box I bought and mounted on the 72 frame with the 72 tie rods/etc. ( I bought the 80's box for the metric fittings for the 5.3 I installed.)
Whether the 73 pitman is shorter I can not comment.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 04-24-2012, 07:27 AM   #8
LostMy65
LostMy65's Avatar
It would be nice to confirm if the 72 pitman arm is longer. Longer pitman arm equals better turning radius.
Old 09-05-2015, 12:49 PM   #9
LostMy65
LostMy65's Avatar
Has anyone ever confirmed if the 72 pitman arm is longer?
