Old 03-25-2002, 09:43 PM   #1
dion
72 Cheyenne
dion's Avatar
Post Oil Pressure Problem
Well the rebuilt has been in for a week now, it runs and sounds great but today only while on the Freeway at high speed the Oil Pressure sometimes drops WAY down and right back up again, it happend four or five times in a ten min period, any ideas?
Restored 72 Cheyenne C20
San Diego, CA
Burnout
Idle
1972Cheyenne
1966/67Stouts
dion is offline   Reply With Quote
Old 03-25-2002, 09:46 PM   #2
704x4
Post
somtimes assembly lube can do a number on your oil filter try changing the oil and filter and tell us if it worked
most of the time it reads a steady low pressure but i thought i would mention it anyhow
70 3/4 ton 4x4
FOR SALE
Greene, IA
704x4 is offline   Reply With Quote
Old 03-25-2002, 09:47 PM   #3
67Blacksheep
Post
Are you running a mechanical guage?? I had problems with the factory one and switched to a triple gauge Sunpro. No fluctuations since. Good luck!
67 Chevy C20 LB Stepside,
350 4-bolt with goodies.
'94 GMC Seirra Ext. Cab
'67 Formula Firebird
'89 GSX-R 750
67Blacksheep is offline   Reply With Quote
Old 03-25-2002, 09:56 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
Dumb question here, you have checked the level haven't you?
I'd change it too.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
Need to pick up the one ton Longhorn with a PONTIAC 350/350soon.
Thanks every one!
Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 03-25-2002, 10:10 PM   #5
dion
72 Cheyenne
dion's Avatar
Post
We just changed the oil a couple of days ago, I checked it and it's good. They ran it with a gauge and it was fine, I'm thinking it's the factory gauge just jumping around, I hope.
San Diego, CA
Burnout
Idle
1972Cheyenne
1966/67Stouts
Old 03-26-2002, 10:40 AM   #6
dion
72 Cheyenne
dion's Avatar
Post
ttt
Burnout
Idle
1972Cheyenne
1966/67Stouts
Old 03-26-2002, 02:06 PM   #7
Spoof
Spoof's Avatar
Post
I had the same thing happen after I tore down my 402 and put in a new cam. Scared the crap out of me. I have to assume it was rtv sealant or assembly lube in the gauge line or something like that.
71 GMC 2500 Custom Camper
71 GMC Suburban 1500 Super Custom
71 Chevrolet 1500 Donor
http://www.able-bravo.com
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
Old 03-26-2002, 02:18 PM   #8
wlee
Just an Old Mr Goodwrench
Post
I switched engines a couple of years ago and ever since my oil guage goes off the scale at start up - only to run "normal" after warm-up. Factory guages do strange stuff! Lee
1969 Custom 20 Longhorn
1970 CST 20 Fleetside
1950 Plymouth Special Deluxe
1991 Jaguar Sovereign
1992 Mazda Miata
1969 Triumph Bonneville
1964 Harley Sportster
1969 CST 20 Longhorn
1992 Mazda Miata
wlee is offline   Reply With Quote
Old 03-26-2002, 02:52 PM   #9
68 Stepside
huh?
68 Stepside's Avatar
Post
Yeah, my factory gauge with the old 350 went way past the High pressure line at startup, and would sit there pegged until warm up, then it would go all the way down and the needle would sit on the "L" Line, when I finally got a cheap aftermarket gauge, I had about 2 lbs of psi at hot idle in gear...pretty good huh? LOL I recommend buying a cheap little wal mart Oil psi gauge and installing it under the dash for the time being, to see if perhaps the factory gauge is just being odd, anything is possible.
68 SWB S/S, 406 sb (the Mighty Mouse), 660 Holley, Computer Dyno'd at about 330 HP, and 385 LB. FT. of torque,Vette Exhaust Manifolds, Torker 2 intake, TH350, baby blue/red oxide primer,
Gridley, IL
tjharvey68@hotmail.com
I'm on MSN messenger under that address if you would like to add me......
Also on AOL IM under the nick tommy85z
My Personal Homepage
The 67-72 gallery on MSN, feel free to submit your pics!
A pass-time of mine is storm spotting, click here to see Gridley IL's Emergency Services Homepage.
AOL SN- Tommy85z
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
