09-25-2011, 07:33 PM | #1 |
What Did You Do With Your Truck Today ?
Ok, the 60-66, 67-72, 73-87, and 88-98 guys have a thread called "What Did You Do To Your Truck Today". Well I say it is time the 47-59 forum has a similar thread, so I decided to start one. Anybody want to join in ?
My Build Thread 51 chevy http://67-72chevytrucks.com/vboard/s...d.php?t=437496 48,49,50 Chevy trucks. 41 Olds |
09-25-2011, 07:41 PM | #2 |
Re: What Did You Do With Your Truck Today ?
I started sanding down the rusted beat up front bumper it came with, too muggy to paint today though.
09-25-2011, 08:18 PM | #3 |
Absoultely nothing today see my build what I did friday and saturday!
Made rear bumper brackets and brake handle cable set up plus cut down original handle and helped my neighbor dissamble his recently acquired project. http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
09-25-2011, 07:57 PM | #4 |
today i installed my accelerator pedal assembly (aftermarket), finished installing my windsheild with the deluxe trim, and started installing my doors (after getting the first one hung I realized I cant effectively adjust the door alone, will put that one off until i can get help.
Windshield looks good though! Still havent got my back glass in all the way... pounded and pounded and I cant get it in far enough to install the bead lock... grr.... |
09-25-2011, 08:17 PM | #5 |
Well I guess since I started this thread I should post what I did to my truck. Went out and looked at the frame work me and my buddy got done yesterday. We got the Malibu clip spot welded in. Did some more measuring/ re-checking to see if we got it right , and to make plans for next move on it next weekend. It was great to finally get the frame rolling again.
09-25-2011, 08:17 PM | #6 |
sand blasted my inner fenders
04-21-2013, 07:40 PM | #7 |
Paint stripped, etch primed,epoxy painted white and color sanded too!
04-21-2013, 07:54 PM | #8 |
big guy
All that paint work in one day damm your good!!!! and it looks good too
Ray |
04-21-2013, 09:15 PM | #9 |
bunch of small stuff and got the auxiliary dash leds mounted in the old ignition hole. Boxes are starting to arrive!
04-21-2013, 09:48 PM | #10 |
Looks nice Orrie.
09-25-2011, 08:20 PM | #11 |
I rolled the cab onto its back and finished welding the new floor, cab mounts and interior cowl panes and undercoated the complete bottom.
09-25-2011, 09:03 PM | #12 |
Finished boxing in and painted new the C-notch I started last week, built and painted a cradle for the new gas tank, installed new rear bumper, then I painted it.
Dont get too excited, when I say "painted" I mean I pointed a spry can and it and held down the button 'till it was all the same color of black... |
09-25-2011, 09:40 PM | #13 |
09-26-2011, 05:57 PM | #14 |
05-09-2012, 05:30 PM | #15 |
I want to do something similar to my 48, if you dont mind sharing the info, where did you buy and how much did you spend?
by the way, they look GREAT!!!!
Semper Fi Check out my project: http://67-72chevytrucks.com/vboard/s...d.php?t=559086 |
05-09-2012, 05:53 PM | #16 |
big guy
i painted my rear fender! This is my first time doing my own body work and paint.
Thanks Ray |
05-09-2012, 07:21 PM | #17 |
Looks great Ray
05-15-2012, 04:08 PM | #18 | |
Is it satin or are you clear coating it? |
05-15-2013, 10:13 PM | #19 |
I got the cutting and drilling done on my motor mounts. these bolt to my Camaro clip replacing the clamshell mount. I made them to use 70s Camaro shackle bushings.
05-16-2013, 08:49 AM | #20 |
big guy
05-16-2013, 09:17 AM | #21 |
Thanks Ray,
They just didn't look right without holes. But next tome I will drill the holes BEFORE I cut the parts out. Some days I get the cart ahead of the horse. They replace these. the plate welded to the frame under the motor mount is to move the mount to the rear a couple inches. Last edited by mknittle; 05-16-2013 at 09:25 AM. |
05-17-2013, 02:04 PM | #22 | |
polishing a turd
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
05-17-2013, 06:28 PM | #23 |
nice job!
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
05-17-2013, 08:44 PM | #24 |
09-26-2011, 11:02 AM | #25 |
I have removed all old wiring and just starting installing an EZ-wire harness in my 57.
Lazypineapple: wheels and tires look great. I can't wait to get my whitewalls. |
