vacuum leak/ vacuum hose help, urgent
so I started the truck up today after driving it last night with no issues.... I got about 30 seconds in the warm up of the motor and heard kinda a pop followed by what sounds like a bad vacuum leak.... so i stopped the motor and took the cleaner off and noticed the below (see picture). what connects to that and shouldn't there be something..... maybe plugged off. I couldn't find anything else
![]() also where does this hose plug into, its been plugged since I got the truck.. mabe I need to get it plugged up in the right spot... ![]()
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
Re: vacuum leak/ vacuum hose help, urgent
The intake port is a take off for a/c- do you have a/c? if not block it off and call it good-I guess some one have been using it for power brakes as well. If you have neither block it and call it good. The port on the carb is a full vacuum port that attaches to the breather for the cold air pull off on the snorkle. Again if no stock breather it is not needed and can be blocked as well.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
thanks .... I found a plug that must have came of the port..... so I reattached it and secured it better then I blocked off the other one and started the truck back up..... seems to be running good agai... that was weird ... for it to all of a sudden come off... man it sounded like a big vacuum leak and stumbled like crazy.... never the less glad to have it running again
Don't park that truck anywhere close to Scoggins/Markham is you don't want it to disappear! I built the Lincoln Corner guvmint subtuhdized apartments there. I apologize.
yea, thanks..... I hear ya... been here many years and of course I know it all too well..
