09-27-2011, 09:09 PM | #1 |
Question on radiator catch can
Thinking of building myself a radiator catch can and was wondering does it need to have a cap or can it just have the entrance fitting from when it overflows out of radiator? Also does it need to seal so that it will pull coolant back into radiator or do they not do this? Thanks for helping
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
09-28-2011, 12:08 AM | #2 |
Re: Question on radiator catch can
As long as the tube goes all the way to the bottom of the catch can, it will draw up any liquid that's in the catch can. No seal is needed.
I use a Jack Daniels bottle.
65 SWB BBW - 283, TH400 |
09-28-2011, 12:11 AM | #3 |
~Rest In Peace~
i got one from summit racing plastic bottle with mount bracket
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
09-28-2011, 04:55 AM | #4 |
yes you need the proper type of radiator cap for a coolant recovery system to work properly and using glass container is a pretty foolish thing to use for an overflow catck can
09-28-2011, 05:57 PM | #5 |
I think driving a 43 year old truck with manual 4 wheel drum brakes, a gas tank sitting behind your back, and it's best safety device being lap belts while in modern vehicle traffic a pretty foolish thing to do too.... but I do that also.
09-28-2011, 08:43 PM | #6 |
LOL
Curt 1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear |
09-28-2011, 09:00 PM | #7 |
Is it necessary to have it function as a coolant recovery system? Or if I just have it as a occasional overflow and so that I can go on the track is that enough? I was thinking of welding some caps on a piece of exhaust pipe, coating it with some Kreem that I have laying around and powdercoating the outside of it and then putting an AN fitting in the top of it that goes to nipple on radiator neck.
LowGT that is a sweet looking LWB, if it had been me I would have done it with Maker's bottle instead I think :-P
09-28-2011, 09:40 PM | #8 |
I had a buddy that had a toyota tercel in his back yard that he was using for parts. Asked if he was using the overflow tank from it. Got it for free, bent the mounting bracket from the toyota and used an existing hole on the fender to mount it to, ran the hose from the tank to the radiator and done.. 30 minutes.. Took longer to drive to his house to get it.
09-28-2011, 10:20 PM | #9 | |
RAT1968 '68 Cab/'71 Parts
Using up a good bottle of Kreem and then powder coating has to cost more than that.....no?
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
09-28-2011, 11:21 PM | #10 | |
Without the valve on the bottom open all the time the tank quick pressurizes to the same pressure as the rad...which means nothing is going in. Find one with a cap and over flow and return connections.
1967 SWB C-10, BBC 454, T400, 3.73 posi, 20" Coys 1972 K5 Blazer, SBC 400, 4 spd, 3.73, 6" lift, 35" mud grapplers 2011 Sierra Denali HD, 6.6 L Duramax, RBP 96R rims, leveled and Nitto trail grapplers, 2009 Acura MDX |
09-29-2011, 01:48 AM | #11 | |
If you had an EXACT ONE like this that didn't work, I would be really pleased to find out before I put it to the test. I appreciate the info. And I'd REALLY APPRECIATE a follow-up so it doesn't get messy in there.
09-29-2011, 02:56 AM | #12 |
~Rest In Peace~
where is your hamster ?
09-29-2011, 05:51 AM | #13 | |
You do need a catch can to run at a legitimate race track, but I would check with them about using glass?
Bach in the day there were several cars that had glass bottles, Ford even used plastic bags at one time, but I don't know if those meet race track standards.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
09-29-2011, 11:33 AM | #14 |
I'm a little thick this morning...only one cup of coffee so far.
You see a nest somewhere? Maybe a man-made nest?
09-29-2011, 12:15 PM | #15 |
I think he is referring to your engine...
www.tomthetruck.blogspot.com <-- Aka build thread. |
10-01-2011, 03:16 PM | #16 |
On EBay I see that there is a stainless steel polished 18 oz can for 25 bucks. 10 dollars shipping sucks but that's pretty hard to beat plus its SS. I think I will just go that route.
