Old 09-28-2011, 08:32 PM   #1
bucannon
Salty Sailor
bucannon's Avatar
Cool 3/4 ton -vs- 1/2 ton question
okay so recently i have finally found out from 1000 miles away why my lower control arms will not center up on the k frame. and it left me thinking if Rock Auto really skrewed up the lower a arms or if the "holes" in the lower control arm shaft are spaced further apart on a 3/4 ton than they are on a half ton.
because thats why my lower a arms have to come off and i have to pressure wash, paint, put new bushings, and transfer the balljoints into my original lower control arms....
i would just switch the shafts but the way they are connected to the control arm is different than the original.
if yall recall from my build thread i had to modify the shock mounts to get the shocks to fit also. Rock Auto will be recieving a nasty letter from me once this is all resolved.
86 c-10 Custom Deluxe
Savannah, Georgia
bucannon is offline   Reply With Quote
Old 09-28-2011, 08:33 PM   #2
bucannon
Salty Sailor
bucannon's Avatar
Cool Re: 3/4 ton -vs- 1/2 ton question
here is a picture so yall get the idea of what im talking about
Savannah, Georgia
Old 09-29-2011, 02:35 PM   #3
78 Chevyrado
1/2 ton will have rubber bushings in the control arm shafts and a washer and nut on the ends.
3/4 and 1 tons have steel bushings that thread on the end of the shaft AND into the control arm itself. it IS the nut and has a grease fitting in the center of the end.
This one is a 3/4 ton steel bushing.
78 Chevyrado is offline   Reply With Quote
Old 09-29-2011, 09:40 PM   #4
bucannon
Salty Sailor
bucannon's Avatar
Thanks for the help but thats the one thing i already knew. i want to know if the 3/4 arm will go on a 1/2 ton k-frame normally.
Savannah, Georgia
Old 09-30-2011, 08:44 PM   #5
bucannon
Salty Sailor
bucannon's Avatar
does anybody know if the tabs on the 3/4 ton k frame and 1/2 k frame are the same?
Savannah, Georgia
Old 10-02-2011, 08:23 PM   #6
bucannon
Salty Sailor
bucannon's Avatar
hope this will further explain what im needing to find out. if the distance between the two holes are different also if the bore size is the same
Savannah, Georgia
Old 10-04-2011, 11:58 PM   #7
BigRed76
BigRed76's Avatar
Just a quick question...what do you mean by a k-frame?
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 10-05-2011, 10:24 AM   #8
bucannon
Salty Sailor
bucannon's Avatar
sorry i must be talking some Mopar talk haha. you know the x member where the engine sits on and in 2wd where the LCA mounts to
Savannah, Georgia
