Old 09-29-2011, 07:56 AM   #1
csa daddy
csa daddy's Avatar
air bag fittings
ok im just about ready to put all my suspension together but i still need fittings an airline. ihave 8 1/2 smc valves two viair 480c comp firestone bags 1/2" ports. bags are in but thats about it. anybody see anything else i may need except a air tank. any help would be appretiated this is the first time i have done air so not sure what all i need. also i have 4 three position toggle switches i was going to run to control everything
csa daddy is offline   Reply With Quote
Old 09-29-2011, 08:38 AM   #2
JWall
Frequent Flyer
JWall's Avatar
Re: air bag fittings
Pressure switch
Fuse for power wire
- Justin
1 Owner 1976 SWB
Old 09-29-2011, 09:38 AM   #3
6772owner
Gearhead
6772owner's Avatar
A drain fitting for the tank and an inline filter/water separator would be nice, I wish I had done those... I also wired a switch so I could manually turn off the compressor if the pressure switch fails or I need to shut down the compressor for any reason, i.e. drain the tank....
Oh and gauges??
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 09-29-2011, 05:00 PM   #4
JWall
Frequent Flyer
JWall's Avatar
More good points... if you run a water trap before the tank you'll be amazed how much moisture you catch & yes a master power shut off to the air ride is nice too.
- Justin
1 Owner 1976 SWB
Old 09-29-2011, 04:42 PM   #5
tubbedII
needs more $$$
tubbedII's Avatar
If you have 1/2 all the way through, you might want some type of flow control...I hear it's awfully fast.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 09-29-2011, 04:58 PM   #6
JWall
Frequent Flyer
JWall's Avatar
Yeah on my old truck I put fittings in my 1/2" valves that reduced to slow them down.
It was awful hard to adjust by just a few PSI at a time.
- Justin
1 Owner 1976 SWB
Old 09-29-2011, 08:52 PM   #7
csa daddy
csa daddy's Avatar
thanks any suggestions on where to get the best deal on air fittings for this
Old 09-29-2011, 10:12 PM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
I know Fastenal carries "push-to-connect" brass fittings.
Just make sure you get DOT approved fittings,... and use some Loctite 545
Hydraulic thread sealer.
Keith
Convert to disc brakes.
Old 09-29-2011, 10:52 PM   #9
Shane
Shane's Avatar
You will pay more, but do yourself a favor and buy name-brand fittings ... Parker or Swagelok preferably. You will thank yourself later when you are chasing leaks on the less expensive ones.
I purchased all of mine from my local Parker store but not sure if there is one located near you.
Shane is offline   Reply With Quote
Old 09-30-2011, 12:42 PM   #10
tubbedII
needs more $$$
tubbedII's Avatar
I too got mine at the local Parker store...a little spendy, but it was nice to be able to get them all minus shipping and right away.
1970 2wd Blazer
