09-29-2011, 09:12 PM | #1 |
Ridin' Dirty
Kingpins discontinued for my Dana 60????!!!
So I tried buying kingpins for my Squarebody Crewcab 4x4 with a Dana 60. The truck is a 1990 Chev V3500.
I dropped by my local family owned parts supplier and was told that they didn't carry them. So I went to Napa who told me the same thing. So I call a GM dealer who called it a "socket" and said it was discontinued. So I called Partsource who also didn't carry them. So I went to NAPAONLINE.COM and only found a kingpin BUSHING kit, https://www.napaonline.com/Catalog/R...+50014+2014047 I've never done kingpins before, is it common to only need the bushing? Am I asking for the wrong thing? Are these considered to be ball joints?
1978 C3500 Crewcab (Project) 1979 C2500 Crewcab (Driver/project) 1988 R2500 Crewcab (Driver) 1988 V3500 Crewcab 1988 R2500 Crewcab (Mint, Ex Fire Dept) 1968 Chev Suburban (4x4 conversion) LINK 1970 Chev C20 Suburban (driver/cruiser)LINK 2005 Impala (Incognito vehicle) 2004 Yukon XL Denali (Kid hauler) 1947 Case tractor Facebook Page(1000's of pictures of GM cars and trucks organized into albums) YouTube Channel |
09-29-2011, 09:18 PM | #2 |
God is good!
Re: Kingpins discontinued for my Dana 60????!!!
No, they're certainly called kingpins. However, some do mistakenly call them ball joints.
Mando "It takes a smart man to know when he's stupid." -- Barney Rubble My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367 |
09-29-2011, 09:28 PM | #3 |
Ridin' Dirty
Ok thanks.
09-29-2011, 09:26 PM | #4 |
God is good!
Do you have part numbers? I tried Rockauto.com and they have the same bushing kit. It is under "steering" as opposed to "suspension".
09-29-2011, 09:37 PM | #5 |
Ridin' Dirty
Ok cool. So I checked out the site. Now I'm wondering if it's the knuckle bearing or the bushing or both that I need, or if there's still something missing. It's kinda hard to tell without a pic of the part. Maybe I can find a diagram somewhere.
09-29-2011, 09:40 PM | #6 | |
God is good!
http://www.pirate4x4.com/tech/billav...pin/index.html
09-29-2011, 09:27 PM | #7 |
Go to Fleet Pride, that is where I got all my 60 stuff....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
09-29-2011, 09:38 PM | #8 |
Ridin' Dirty
I clicked on kingpin in the index, and it gave me parts for a tractor trailer 5th wheel.. haha
09-29-2011, 09:41 PM | #9 |
Ridin' Dirty
Edit: so I guess there where pics of the bearing. I'm guessing there's more to that to fix the major amount of play that I have in both the upper and lower kingpins..
Oh, and I forgot to get a part number from any of the parts guys today.
09-29-2011, 09:50 PM | #10 |
Ridin' Dirty
SWEET Awesome links! Thanks, that will help alot. Do I have to pull the axle to get them out???
09-29-2011, 09:39 PM | #11 |
God is good!
Here are a few links, hopefully they help...
http://compare.ebay.com/like/2304918...=sbar&_lwgsi=y http://www.riversidegear.com/dana-60...odge-ford.html http://www.pirate4x4.com/tech/billav...pin/index.html
09-29-2011, 09:59 PM | #12 |
God is good!
I've never done a Dana 60, but yes, you will need access to them with the axles removed, but I wouldn't sweat that. It will give you an opportunity to replace the inner axle seals, which you had BETTER do at the same time.
Now is a good time to go through all the seals and bearings.
09-29-2011, 10:01 PM | #13 | |
Ridin' Dirty
09-29-2011, 11:46 PM | #14 |
Formerly- 1972SuperCheyenne
OK man, i just did mine, check it out. It is VERY common only to need the bushing in the top and not the whole Kingpin. You do not have to remove the axles, or even the brakes to do the top. Just take the 4 bolts out of the cap and remove the white bushing. SUPER simple. I did replace the Kingpin while I had mine apart because, well, i figured might as well. You will need a big ass 7/8 allen wrench to remove the kingpin itself. i have one you can borrow if you pay shipping. But theyre not too expensive. I used the 7/8 allen wrench and a jack handle cheater bar. The bottom has a bearing, not a kingpin. You can remove the lower cap, replace the bearing and reinstall. You dont NEED to replace the race unless its rough, pitted, etc... but again, I figured might as well.
I got my kingpin rebuild kits from Off Road Design.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
09-29-2011, 11:57 PM | #15 | |
Ridin' Dirty
09-30-2011, 04:15 PM | #16 |
Newbee
More often than not, you are going to need a torch to heat up the C that it threads into. They can be REALLY stuck in there!
09-30-2011, 04:37 AM | #17 |
Try these: http://www.wfoconcepts.com/pr/Dana-6...3164/3172/3435
They're from WFO Concepts - the shop building my truck. Should work for ya!
1977 Chevrolet K30 LWB Crew Cab 497HP Mast Motorsports 6.0L LY6 HO engine GM NV4500 5-speed, Centerforce clutch + NP205 D60 + 14-bolt FF w/ Eaton posi + disc brakes Skyjacker 2.5" full spring lift w/ Nitro shocks Custom paint + interior http://67-72chevytrucks.com/vboard/s...d.php?t=435722 |
09-30-2011, 09:33 AM | #18 | |
Ridin' Dirty
09-30-2011, 03:41 PM | #19 |
I was looking at my recepits last night, I actually got mine from WFO as well. Same brand and all.
10-08-2011, 01:00 PM | #20 |
CHEVY ONLY |
10-08-2011, 10:39 PM | #21 |
Ridin' Dirty
Sorry, my hands were too dirty for the camera! lol.. The links that were given have lots of pics..
10-09-2011, 10:40 AM | #22 |
Glad it was an easy repair. Like I said, its usually just the bushing!
10-09-2011, 11:03 AM | #23 |
Ridin' Dirty
This is the first time I've done any front end work on a Dana 60, so it was all new to me. I thought the king pin assembly was going to be all replaced as one piece like a ball joint, which is why I was trying to order more parts than I needed before I ripped it apart. I just wanted to have all my parts ready before I took it apart.. It was easier than I thought it would be for sure!
10-09-2011, 05:49 PM | #24 |
"coholiquidation.com" has bushings for $2 for a pair. They still have 111 available, Ron
Tags |
chev, dana60, king, kingpin, pin |
