Old 10-01-2011, 01:44 PM   #1
threeonthetree
threeonthetree's Avatar
Cannot Find This Part please help!
no one sells it anyone else run into this problem?
link.
https://www.napaonline.com/Catalog/C...(P_RecType%3aA)
threeonthetree is offline   Reply With Quote
Old 10-01-2011, 02:00 PM   #2
maskale
Re: Cannot Find This Part pleas help!
i get an error message when i click
maskale is offline   Reply With Quote
Old 10-01-2011, 02:29 PM   #3
jdheff1982
I guess we can't find the part either....
Project and Truck Specs: http://67-72chevytrucks.com/vboard/s...d.php?t=483381
jdheff1982 is offline   Reply With Quote
Old 10-01-2011, 02:58 PM   #4
threeonthetree
Part is for the clutch it is the hydralic line in between the master and the slave.
no one carries it.
Old 10-01-2011, 03:13 PM   #5
jdheff1982
http://www.lmctruck.com/icatalog/cc/full.aspx?page=139
Look at bottom left pic. It is #6.
Old 10-04-2011, 01:26 PM   #6
raceman6135
Dino burner
raceman6135's Avatar
Ask your local parts store if they carry, or can order, Dorman H38559 - lots of jobbers have access to the Dorman/Motormite line.
raceman6135 is offline   Reply With Quote
Old 10-04-2011, 09:21 PM   #7
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
FROM NAPA's prolink websight.
Clutch Hose
Part: UP 38559
Product Line: Brake and Clutch Hoses and Cables
Features & Benefits
Direct Replacement Hydraulic Brake Hose Designed To Fit Specific Vehicle Applications & Positions; Hoses Constructed Of EPDM Rubber & PVA Braid, Offering High Dynamic Strength, Chemical & Thermal Resistance; Brake Hoses w/ Banjo End Fittings Are Packaged w/ New Copper Washers To Assure Proper Sealing; Brake Hoses Tested Up To 4,000 psi
Attributes
Caution Statement : Do Not Use w/ Petroleum-Based Fluids - Designed Only For Use w/ DOT Approved Silicone Or Glycol-Based Brake Fluids
Clutch Hose End Type : Male - M12 x 1.0 & Male - M12 x 1.0
Clutch Hose Length : 21.25"
Local store up here has one in stock.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 10-04-2011, 10:42 PM   #8
67_SS396
Re: Cannot Find This Part please help!
Oreilly can get them. I had one made out of steel braided line at a hydraulic shop for MUCH less than any of the factory replacements were.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
