Old 04-13-2003, 11:37 PM   #1
wHATANERD
wHATANERD's Avatar
Question Core Support Help ????
Help!!!! I am reinstalling the Radiator Core support on my 1969 C/10, I've had it off for quite some time and have forgotten how the Washers and spacer are installed to the Frame Rails. Does anyone have any photos of how they go back, our the ability to explain it would be greatly appericated, Thanks
1969 C/10 Longbed undergoing rebuild.
Old Chevy's Never Die, They Just Rust Around The Edges
wHATANERD is offline   Reply With Quote
Old 04-14-2003, 12:08 AM   #2
hobby67stepside
This ought to help. Ran out to my shop at 11:00 PM to get this.
  • '05 2500 HD Silverado 6.0 liter
    '97 2500 4X4 454 eng
    '92 2500 4X4 350 eng
    '78 K20 4X4 400 eng
    '70 Boss 302 (owner for 27 years)
    '57 Ford shortbox 383 stroker TH350 tranny
    '23 T-bucket (built in '78)
    '02 Explorer
    '67 C-10 short step
NW Iowa
hobby67stepside is offline   Reply With Quote
Old 04-14-2003, 12:42 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Interesting, that looks nothing like what was in the Longhorn's front clip.
Well, it is close, a couple of the bushings are almost an inch tall on mine, and there is a metal sleeve that goes into it on mine.
Old 04-14-2003, 12:49 AM   #4
hobby67stepside
Oops, I just noticed - this diagram is up to '68. Sorry, I tried to help.
Old 04-14-2003, 07:23 AM   #5
GMCPaul
Thumbs up
From the top of core support
Carriage Bolt
Square Washer
Under The Support between support and frame
approx. 1" thick pad with steel insert has a ridge on bottom middle that extends down through hole in frame
Steel sleeve inserts through center of this and into pad under frame
Under the core support frame bracket
Pad with beveled edge beveled edge points down steel insert inserted in pad above frame inserts into this pad also
Steel Round Washer
Nut
Thats the order they go in from top to bottom the above picture is for 1960-68 mounts.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 04-15-2003, 10:19 PM   #6
wHATANERD
wHATANERD's Avatar
Thanks for the information, The previous owner of my truck had used 67-68 type mounts, I have corrected this and went back with the proper type mounting, everything went on fine. The truck should be back on the road next weekend.
