10-03-2011, 12:16 PM | #1 |
Body laying on transmission--help!
I just put a 700r4 in my 66. It previously had a 400th. Now the transmission is butting up to the "pinch weld" in the trans tunnel. the only difference is I moved the crossmember about 4 inches. I need to drop the tail about an inch to give me clearance. The truck has a low tunnel floor in it. (is that why everyone likes the high tunnel?) Just wondering if anyone else has had an issue. Do I need a different crossmember?
10-03-2011, 01:03 PM | #2 |
Re: Body laying on transmission--help!
what are the body mounts like, new or old. ant rust in the cab supports or floors.
you may have to do some work on that seam. c10 or 20? ron |
10-03-2011, 01:35 PM | #3 |
Take some pics of where it's hitting and we can help you out a bit more knowing exactly what's going on.
Check out my build thread for my '63: http://67-72chevytrucks.com/vboard/s...49#post4806049 |
10-03-2011, 02:12 PM | #4 |
I used newer style motor mounts (91 burb) moved forward all the way and used a cpp transmission crossmember. My 350 700r4 cleared just fine. (very lucky wasn't I) Kieth
10-03-2011, 02:24 PM | #5 |
I'll try to get some pictures tonight, may be hard to tell. The truck is back together. Had i known there would have been a clearance problem I could have trimmed or bent the pinch weld. It's a lot more difficult at this point.
10-03-2011, 03:38 PM | #6 |
I know that when member Chevy Fleetside installed his 700R4 he had to bend that lip back to get it to fit.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
10-03-2011, 04:26 PM | #7 |
That is what I did with both trucks. It only hits at the top so if you be nice with a hammer and bend the lip back about 1/2" it will clear. Can you see it in this picture? Just follow the lip and you will see how little it has to move. Oh yeah. easier to do with the tranny is not in there.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
