10-03-2011, 07:32 PM | #1 |
Active Member
body torque specs
Put new body bushings under a 74 blazer 4x4. Does anyone know the torque spec and possibly sequence to bolt the body down. Thanks.
Posted via Mobile Device |
10-04-2011, 01:06 PM | #2 |
Active Member
Re: body torque specs
I thought with so many knowledgeable board members this would be a simple question. I find it hard to believe that not a single person has replaced there body bushings. Thanks anyway guys.
10-05-2011, 07:31 AM | #3 |
There may be members who have swapped the bushings, but most of us just tighten 'em down until just before they break
I use torque specs on engines and drivetrains, never heard of 'em on body panels, etc. |
10-05-2011, 07:51 AM | #4 |
I'm sure there is spec's on the body bolts , they are a 1/2 grade 5 bolt so I would say 75 dry and if you antisize the bolt 50 foot lbs ... general rule till the bushing squishes and a little more .
10-05-2011, 08:07 AM | #5 |
agree - and there is no sequence. Just tighten em down as you see fit (just make sure the body is sitting straight on the frame rails).
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-07-2011, 01:25 AM | #6 |
Active Member
I did find a link on the web with a factory assembly manual diagram for the fully removable top. Factory ass. Manual says 35-55 foot pounds. I went 45. Met in the middle. But it did have a VERY helpful diagram of the body and mounts and how spacers are used to adjust door to fender and door to rear quarter GAPS. Without this diagram I would have never gotten the doors to align properly. So through my dedication I found the correct information to do the best possible job I could do to not create more problems down the road. Such as paint chipping every time I close the door because I tightened the bolts twice the amount needed. I ask that everybody strive to do the best possible job so that are hobby may continue. To many of my customers complain of poor jobs because the last specialist didn't take the proper steps to ensure a quality job. I care about my product and service and will do whatever it takes to ensure the job was done properly. 6 hours to find torque specs and sequence. But it saved the body guy hours of labor trying to get panels to fit properly. Wich in the end saves you money.
10-07-2011, 02:08 PM | #7 |
You seem to be much more dedicated than the individuals that put them together in the first place
Funny story about those "spacers" - or what I presume to be multiple shims taped together: We used to run a particular set up, like maybe three shims taped together, and each truck would get that package whether it needed it or not. We would run that way until I got a call from the supervisor in Final Repair, who would say something gracious like: "YOU F#*K%N@ IDIOT!! ARE YOU EVEN LOOKING AT THIS $#IT YOU ARE SENDING ME!! FENDERS ARE 1/4" HIGH; ARE YOU GOING TO MAKE ME COME BACK THERE AND FIX THIS XX#@T MYSELF?!? I WILL GET YOU FIRED AND FIND SOMEONE ELSE TO RUN THAT DUMP!!" So - at that point, I would quietly hang the phone up and tell my guys "...take a shim out". We would run that way until the next phone call from Final Repair. This cycle would continue over a period of ten or fifteen years worth of production. (lol) K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 10-07-2011 at 02:24 PM. |
10-08-2011, 01:30 AM | #8 | |
