Old 04-14-2003, 10:13 AM   #1
lotik
drag it like you stole it
kickdown cable bracket..
anyone have a pic of one of these installed?
negative camber //LA\\
lotik is offline   Reply With Quote
Old 04-14-2003, 12:33 PM   #2
COBALT
COBALT's Avatar
Depends on the transmission: TH350 is mechanical and TH400 is electrical, unless you go with a custom setup like I did which looks mechanical from the carb, but actuates a switch mounted on the frame...
I can snap a pic of my custom setup, but it may be a while before I can get it to you (no digital camera good enough...).
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 04-14-2003, 09:07 PM   #3
SideStepper
On the same topic, does anyone have a GM part number for a kick down cable use with a 350 engine, 350 trans. & Quadrajet 4 barrel carb. I don't know how to find the # or length required. Thank you!
SideStepper is offline   Reply With Quote
Old 04-14-2003, 10:00 PM   #4
slam33
slam33's Avatar
If it's for a 350, it bolts to the left side rear of the manifold. You can get them at the car and truck shop. http://www.truckandcarshop.com/
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
