Old 10-04-2011, 10:48 PM   #1
86chevysky
86chevysky's Avatar
New direction lsx build
Ok i have a 69 chevy 350 4 bolt main. where do i start on turning my motor into an ls based motor. I was going to turbo my truck but i figured i would tear it to fast. i heard i could turn my ol 350 into an ls based motor so i need some help starting. Thank you guy.
86chevysky is offline   Reply With Quote
Old 10-04-2011, 10:53 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: New direction lsx build
Buy an LS motor. No way to turn a Gen 1 into a Gen 3. The only parts that are the same are the rod and main bearings that's it.
Old 10-05-2011, 08:35 PM   #3
86chevysky
86chevysky's Avatar
So what can i get an LS motor out of? And a tranny and wiring harness.
Old 10-05-2011, 08:47 PM   #4
pat565
The easier ones to find are from pickups but car engines are out there. You can phone wreckers in your area to find what is readily available. Trans options include newer types that are behind the engine you what to buy, but you can also use the older th350, th 400 etc. Harnesses can be bought new from people who will build what you need, or you can use the donor harness, and modify as needed, but this will also require getting the computer unlocked, and maybe flashed for engine mods.
Hope this helps get you started
Do some searches in the forums, and you will see most of the answers that you need
pat565 is offline   Reply With Quote
Old 10-06-2011, 09:43 PM   #5
86chevysky
86chevysky's Avatar
Thank you all for the help and info. This will be a fun build.
Old 10-07-2011, 06:18 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
car-part.com and search the local wreckers for an engine
I got a 6.0 mostly complete for less than 800$, fairly low miles
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
