Old 10-06-2011, 12:29 AM   #1
lucky09
front crossmember
so i know alot of of you dont care for having the front crossmember on the gorund, but i was just wondering what you have to do to get the memeber on the floor? that is about how low i wanna go and i really dont have the cash to buy an after market front member. i really wanna get my truck as low as possible i have a full bag setup and plan on putting it all on just need a few tips on how to get the maximum drop. any pics or advise would be great...
lucky09 is offline   Reply With Quote
Old 10-06-2011, 10:29 AM   #2
SCOTI
SCOTI's Avatar
Re: front crossmember
What year truck?
What size wheel/tire combo?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-06-2011, 08:07 PM   #3
lucky09
235/75r15 they are coker american classic white walls and steel wheels and it is a 70' c10 longbed.
Old 10-06-2011, 08:13 PM   #4
SCOTI
SCOTI's Avatar
235-75-15's = /< 29" tall.
3" drop spindles & bags on trimmed down cups should plant the a-arms on the ground.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-06-2011, 09:16 PM   #5
lucky09
and can i use the factory 2 link and just plate it to make it stronger with a c -notch and replace the factory springs with bags? also how big of a c- notch around a 10",thanks for your help.
Old 10-06-2011, 11:51 PM   #6
SCOTI
SCOTI's Avatar
Yes
Yes
how big of a c- notch around a 10"?
Yes
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-11-2011, 01:17 PM   #7
tubbedII
needs more $$$
tubbedII's Avatar
My lcas are about 2" from hitting the ground fully aired out. I have 2 1/2" drop spindles, my tires are just a hair over 29" tall and the cups are cut as far as they can be. It is a blazer and all, but still a 2wd so that shouldn't make a big diff. The only way for me to get the x-mbr on the ground is to now mess with the lca's (outside of the after market mbr).
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 10-11-2011, 03:45 PM   #8
SCOTI
SCOTI's Avatar
Over 29" & less than 29" means being closer to the ground = more drop. Depending on how much over you are over & how much he is under could be up to an inch.
What's limiting your travel?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-11-2011, 05:44 PM   #9
tubbedII
needs more $$$
tubbedII's Avatar
The tire charts show my tire size is 29.1" tall (265/35/22). I could't see anything holding me up from going lower. The bag was fully compressed, and there's about a 1/8th of an inch between the tire and the fender (I don't have inner wells).
I'm going off of memory because it's been on stands for a few months now, but I do know that my long tube headers didn't even hit the floor (maybe 1/8th of an inch from it though) fully aired out.
I'm not trying to say your wrong or anything Scoti...but more trying to figure out if I can get a little lower because I did something wrong. Once back together, I can check if my shocks are limiting the drop, but I don't think I put them on at 1st. Do the upper bj's have a tendency to bind?
1970 2wd Blazer
Old 10-11-2011, 06:15 PM   #10
SCOTI
SCOTI's Avatar
I would thnk either shocks or BJ's might have been possibly limiting you. I know my old 74 was <3" off the ground @ the a-arm shaft w/27" tall tires (static dropped). If there were bags, I could have easily laid the x-member out even w/a slightly taller tire.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-11-2011, 06:19 PM   #11
tubbedII
needs more $$$
tubbedII's Avatar
I thought there was a difference between 67-72's and later gens with how low they got. I thought I read that 73+'ers lay arms with little effort but the for some reason the 1st gens don't. That's the only reason I never thought about looking into anything binding after the bag install.
1970 2wd Blazer
Old 10-11-2011, 07:43 PM   #12
SCOTI
SCOTI's Avatar
Definitely possible. I know both my 68 Beater & the 74 were set up very similarly (3" spindles & 1-coil cut). The 68 had more ground clearance but looked lower visually (not by much).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-11-2011, 11:46 PM   #13
jmedero
jmedero's Avatar
my sway bar and shock are holding me up a bit. I am sure the bj angle is not helping me at all either. Im laid out in the rear and about 2-3 inches shy of it up front myself.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
