Is anyone still running the original generator?
I have been running an alternator for so long, I forgot about the lowly generator till someone wanted to buy my old one!!!
Re: Is anyone still running the original generator?
Did until 2000. Switched over to altenator, sold my two working generators (I always carried a spare in case it puked in the boonies) for $15 to a tri-five restoration guy.
I've still got the generator on mine but mine is in the middle of a restoration and hasn't seen more than 2 miles in the last 20 years.
I carried brushes and bearings in the glove compt. for years, Then when the generator did fail, it was a shorted field coil. Didn't have that in the glove compt. I had to turn on everything to keep from boiling the battery. The 'ol volt meter was reading 17 volts unloaded, and 15 volts with headlights, heater, wipers on a dry windshield, foot on the brake to make the stoplights go on, and the original radio all workin'.
I got a one wire alternator the next day. I used a corvette alternator bracket in aluminum. |
I couldn't begin to tell anyone when the last time I ran a generator on anything of my own was. Probably the 55 Ford Sedan that we had that my wife drove to work for a few months in the early 70's.
I'm building a little roadster with a flathead six in it that may keep the generator to keep the car a bit more period correct but it won't have anything on it that draws power except a little box style heater that hopefully will take a bit of the chill off cool mornings and evenings. a hundred miles one way will probably be the longest road trip it ever makes too unless it is on it's trailer behind the 48. A generator does have one advantage over an alternator though. You can push start a car with a stone dead battery with a generator as it will charge without having any voltage to it to excite it like an alternator needs. |
![]() Join Date: Apr 2009
Still got one on mine. Im about to rewire the beast though, then ill probably go to a powermaster look a like or something, since the motor will be dressed in early vette garb.
Posted via Mobile Device |
![]() ![]() Join Date: Nov 2008
I'm running a generator on mine. I plan to update to a polished alternator at some point but its not a priority. Truck's not a daily driver and it has NOTHING; well almost nothing, electrical to run. No radio, don't drive it with the lights on cause I virtually never drive it at night.
![]() Air cleaner has since been changed to matching finned unit and firewall, inner fenders redone in black. But the generator is still there. |
Oh, P.S. Double hump heads so no holes in the heads for the typical mounts. I've heard there are sources for brackets that do NOT use holes in the heads, but I could use advice or links if anyone has good ones.
Yes... Definitely... Well, until it quits.
Running a generator and have no regrets. I'll be glad to have mine back on the road. Currently under restoration.....$$$
Dan, this guy has the best brackets out there and they fit.
http://www.alangrovecomponents.com/index.htm |
#12 | |
#13 | |
@ Dan in Pasedena
Is your motor the 235? I may have a generator bracket? I will have to dig through my stuff. I'm not sure if I have a bracket with my spare generator or not. Let me know.... |
#15 |
I guess I did not read enough up there.. Your truck is a V8. My generator brackets will not work...
#16 |
Ha, ha I read your first post and was about to say...."Uh....see the photo..."
Solidaxel - Thanks, someone told me about a local shop but I forgot the name and that must be it. Definitely will look into them. |
#17 |
Yup original 235 with the generator. Never worried about it until I read this!
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
#18 |
Original here too in my 59 235, like Dan I have no need to drive at night.
