Step Side's Rule
DANO ![]() ![]() ![]() ![]() ![]() |
OK, I am interested, give us the details! Did you install a new "out of the box" sway bar kit, if so who is the dealer/manufacturer? Was it a junk yard find, if so what is the donor vehicle? I have heard good things from many board members on installing a front sway bar on these old trucks. I don't want to be the last one on the block to put one on! Sounds like Iam goin to have to do it, just to keep up with you guys!
Step Side's Rule
IT WAS FROM A DONOR TRUCK. I PURCHASED IT FROM AN INDIVIDUAL NOT SURE WHAT MODEL. IT WAS AN EASY INSTALL, JUST HAD TO DRILL OUT TWO RIVITS AND BOLT ON. I ALSO USED NEW BUSHINGS. BIG DIFFERENCE IN HANDLING FOR ONLY $35.
I have a 1 1/8" sway bar from a late 70's chevy and picked it up for only $20 at the local yard, and that included all the hardeware
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
I did that same thing a couple of weeks ago-highly recommend it too! I bought the front brackets from the local Chevy dealer for under $10 each, then pulled a 1 1/8" sway bar/clamps/bolts from a mid 80's Suburban for another $10. I used the original bushings, but have ordered new replacements.
It is an easy mod with very noticeable results. I can now go around a corner and not worry about scraping my mirrors on the pavement! Kent
'56 F-100 (w/all GM stuff) Lookin' for another parts chaser! ![]() '05 GMC crew cab |
![]() Join Date: Oct 2001
I also used a 1 1/8 in bar from a donor truck but I mounted it on lowered brackets and polygraphite bushings from Early Classic.
Tom
'69 swb stepside in progress. '59 Corvette lifetime project |
#7 | |
Donor trucks would be 67 to 87, Suburbans would be 67 to 91 (I think that is the right year). Bigger bars are available on heavier vehicles and as optional equipment on those years. Kent
Seasonal Poster
I just did it two weeks ago too...1 1/4" bar made a huge difference. New Poly bushings, the hardest part were the damn rivets, other than that, its was amazingly easy, even while laying on the ground in the dirt.
67 GMC Short Step 350/4-Speed/3.08 Posi Front/Rear Sway Bars Kelowna BC, Canada Member of DTPW |
Step Side's Rule
REAR SWAY BAR
I LIKED THE RESULTS FROM THE FRONT SWAY BAR SO MUCH THAT NOW I WANT ONE FOR THE REAR. ANYONE KNOW OF A GOOD DONOR FOR A REAR SWAY BAR?
i have an 89 Camaro rear bar under my truck. I have a thing about it on my website you check out, just got alot of damn pop-ups.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
Hey, all you guys, thanks for the info! I can see that this is a FAST group to keep up with!
From a 73 Chevy truck up to87 that I know of.
It's definitely worth the time. I should have installed mine a long time ago, but better late than never.
Milan 1964 Chevelle SS 283/M20 |
