10-07-2011, 07:54 PM | #1 |
Fuel Lines and Tanks
I was just wondering if I went to overboard on my fuel system and what you guys are using compared to it. Engine size and horsepower figures added please.
I have a an aluminum fuel cell holding 20 gallons and with it I used both outlets. I have -10 coming from the cell to my Mallory 250 filter and both outlets have -10 going into my Holley Billet 160 pump. From the pump I have a -8 line running to the regulator splitting into -6's to the carb. Im not so sure how power I'm making but when I did race it just to find out how fast it could go I ran 11.83 at 126 mph in the quarter. That's in my ElCo with a weight including me of 3550 pounds. |
10-07-2011, 08:02 PM | #2 |
Re: Fuel Lines and Tanks
A single line -8 would have been plenty. Why the two feed lines to the pump? The pump to the motor sounds perfectly fine. Keep in mind -8 line is 1/2 inch inside diameter and -10 is 5/8's inside diameter. -10 line can feed 1000 plus hp.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
10-07-2011, 09:53 PM | #3 |
i got -10 from tank to pump to regulator -8 return to tank,,,, -6 to quick-fuel 850- 355 ci. solid-roller, super vic, trans brake, 430 gears plan on juicing it . if its to much the regulator has a return,,,room to grow
10-07-2011, 10:30 PM | #4 |
~Rest In Peace~
i went -8 all the way to the carbs it had a -6 poor thing was starving
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
10-07-2011, 10:48 PM | #5 |
Registered Truck Offender
I have the Mallory Comp filter too Dan,, did it the same way but with two 8's to the filter, -8 to a Mallory 250 alcohol pump (but running gas) and -8 all the way to the regulator (-8 return from the vacuum compensated regualator, and a bypass at the Mallory pump) and -8 to both carbs (two 4bbl w/ tunnerlram)
The fuel system is a bit non-typical but it idles at 6, is rock solid at 6 until it goes WOT, then the vacuum compensated regulator kicks it up to 9.5 and it stays there rock solid for the whole pass (data logging so I am positive about the 'dead steady psi' ) Same system feeds the 800HP motor in the Nova and also data logging rock solid fuel psi. OVERKILL is way better than barely enough!!!
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
10-07-2011, 10:54 PM | #6 |
Mean Green
I feed the pump with a -10 also. -8 to reg and the return line in -8.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel. 60'-1.38 1/4-10.43 MPH-124.6 New ET current 4/2019 AKA MEAN GREEN. |
10-08-2011, 09:35 AM | #7 |
I run -12 from the cell to the filter/pump combo, -10 from the pump to a y-block that feeds the regulators up front, and a -8 return from the Magnafuel pump back to the cell. My system is way overkill, but like Marv said, overkill is better than not enough.
Chris 1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas 7.02 @ 95.8, 1.45 60' 1965 Chevy C10 LWB, 355 sbc, TH350, daily driver |
10-09-2011, 01:35 AM | #8 |
My pump has the return built in and its mounted right below the tank. So I have a -8 line running there.
Cableguy I ran both because to and from because I could and I had an in when KB Performance was still selling the fitting themselves [50% discount] |
