Old 10-09-2011, 10:35 PM   #1
DeadheadNM
Carpe manana
DeadheadNM's Avatar
WTB No-spin Eaton locker
Decided to keep the HO52 so hoping to find a no-spin locker. Can anyone help me out?
Thanks, Pete
Old 10-10-2011, 03:40 PM   #2
Ozark Tim
Ozark Tim's Avatar
Re: WTB No-spin Eaton locker
I have one I would sell but have no idea what ratio it serves.
Is there a number on it that verifies what it will work with??
I just have the locker unit itself, no 3rd member or carrier, no ring& pinion.
I thought it was for 4:10's but how to tell???
Ozark Tim is offline   Reply With Quote
Old 10-10-2011, 07:18 PM   #3
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Tim, thanks for the reply. That's all I need is the locker itself. I suspect any HO52 locker will work regardless of ratio but that's just a guess. Let me post the question on the drivetrain forum and try to find out. I'll post back here when I know.
Is the locker in good shape?
Old 10-10-2011, 08:10 PM   #4
w314speed
I have a complete H052/H072 from a 72 3/4 ton 4X4. It is a 4:10.
If you don't need, maybe someone else will see it in the thread. I need $300 plus shipping or local pick-up. Thanks, Dan
w314speed is offline   Reply With Quote
Old 10-10-2011, 08:17 PM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks Dan. Just to clarify, is that a complete rear end or the no-spin locker?
Old 10-10-2011, 08:37 PM   #6
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Ozark Tim - Another member tells me the no-spin locker will work with any series gear ratio. Let me know how much you want for the locker when you can. Thanks.
Old 10-10-2011, 09:02 PM   #7
w314speed
It's the pumpkin that loads into the front of the housing. Ring and pinion,posi unit, case and yoke. Thanks for clearing that up. Dan
Old 10-11-2011, 07:16 PM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Dan - Any chance you'd sell just the locker?
I imagine shipping costs on the whole pumpkin would be very pricey.
Old 10-11-2011, 10:32 PM   #9
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
It is usually a lot easier to install the whole center pumpkin with all the gears set & the patterns "run in"...if the gear ratio is right for you.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 10-11-2011, 10:48 PM   #10
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Frank, I believe it. I hope to save some $ over outfitting the Eaton with a 14 bolt diff and axles. I'd like to have Dan's pumpkin but considering the potential shipping cost of such a heavy piece of steel I suspect I wouldn't save much. Maybe I'm wrong.
Old 10-11-2011, 11:09 PM   #11
RUSHNBOBO
I want to do the same thing with my 4.56 HO72 pumpkin...I've been trying to do some research to see if a Lockright mini type locker will work with the Eaton/14 bolt hybrid....it would have to fit in the Eaton carrier or use a 14 bolt open carrier, haven't seen one yet but don't see why it wouldn't work.
Did find some awesome disc brake brackets which are cut just for Eatons and need no spacers of any kind .....they use '77 14 bolt 3/4 ton rotors and calipers.
RUSHNBOBO is offline   Reply With Quote
Old 10-12-2011, 09:17 AM   #12
HeavyMetalChevy
Just a Member
HeavyMetalChevy's Avatar
I just want a limited slip/posi trac setup for my eaton52...Any suggestions??? I think its 4.11 gear but can get numbers they are worn too bad... I know the ring gear has 41 teeth though but cant have the ration without the other gear number and I dont really feel like pulling it out at the moment..lol
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st)
69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd)
70 C-20 88 350 long block rebuild .040 bore. forged crank
GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum
TH400(3rd)
71 SWB frame off with 68 body. POSI
PayPal: remimartin257@aol.com
Business Inquires: 812 801 5111
"Help me, help you" that's my motto
Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog
HeavyMetalChevy is offline   Reply With Quote
Old 10-12-2011, 10:47 AM   #13
Ozark Tim
Ozark Tim's Avatar
Sent you a p.m.
Old 10-12-2011, 08:41 PM   #14
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Rushnbobo - Where did you get the disk brake brackets and what calipers did you go with? I was planning on using a kit from Blackbirds Custom Trucks: http://www.blackbirdscustomtrucks.com/index.html
Tim - Thanks for the PM
Old 10-12-2011, 09:34 PM   #15
RUSHNBOBO
http://www.ruffstuffspecialties.com/...g/EHO5272.html
Old 10-12-2011, 09:39 PM   #16
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Nice! Thank you...
Old 10-12-2011, 09:54 PM   #17
RUSHNBOBO
Nice! Thank you...
no problem....
Old 10-17-2011, 02:52 PM   #18
Ozark Tim
Ozark Tim's Avatar
Here are the pictures
Old 10-17-2011, 07:28 PM   #19
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Tim- From what I can tell that's a fine piece of steel. Do you know if I need the side springs to install this? Do you have these too? (pic w springs is borrowed from an old board post). I want to buy it just making sure I have everything I'm going to need for the install.
Thanks for the pics. Pete
Old 10-18-2011, 08:44 AM   #20
Ozark Tim
Ozark Tim's Avatar
I know there are springs or spring inside which is why the long bolt and nut are on it to keep it from flying into 3 or more pieces. If you need me to dissasemble and take more pictures just let me know.
Old 10-18-2011, 09:47 AM   #21
DeadheadNM
Carpe manana
DeadheadNM's Avatar
That's good enough for me. I'll take it. Thanks Tim. Please send PM with payment details when possible.
Old 10-18-2011, 10:05 AM   #22
Ozark Tim
Ozark Tim's Avatar
shot you a pm
Old 01-29-2012, 05:41 PM   #23
Beat68CST
Beat68CST's Avatar
Any chance any of you know have one still?
I'd like to get one right now since I just got my third member from another board member and the spider gears were broke, which I knew, I'd just like to find a locker before I put it back together.
Beat68CST is offline   Reply With Quote
