Old 10-10-2011, 06:35 PM   #1
malgieri4
1985 k10 turn signal hazard problem
Help my sons 1985 k10 truck has a problem when he put on the right or left turn signal on the flashers come on, also when he steps on the brake the front and back parking lights come on. please help...........
malgieri4 is offline   Reply With Quote
Old 10-10-2011, 06:39 PM   #2
BIG V
Re: 1985 k10 turn signal hazard problem
Check the towing package, and check if the hazzards are stuck on
1991 Chevy suburban 3/4 ton 4x 4:56 and pulls great
1979 Chevy 1/2 ton long bed diesel
1974 Chevy crew cab short bed 3/4 ton 4x4 project
1991 Chevy suburban 2wd
1984 Chevy suburban 3/4 ton 4x 6.5 detroit with turbo
1961 Chevy pickup 1/2 ton 2wd
1975 gmc crew cab short bed 2wd
BIG V is offline   Reply With Quote
Old 10-10-2011, 07:32 PM   #3
Rogue_Alphonse
Rogue_Alphonse's Avatar
This, and also check to see if the hazard switch is pushed halfway in or is jumping connections inside the steering column.
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc.
1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980.
1998 Jeep Grand Cherokee 4.0 fully loaded daily driver!
Where there's a will, there's a rig!
Rogue_Alphonse is offline   Reply With Quote
Old 10-10-2011, 08:08 PM   #4
john_p
if you haven't found it yet, this is what i would try next.. remove the bulbs, remove the fuses and flasher relay.. then check for crosses with a meter.. two wires pinched together working like a splice.. if you do not find a cross, test for a short between any wire and ground..
most common seems to be wires pinched..
john_p is offline   Reply With Quote
