Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 10-10-2011, 10:21 PM   #1
denny5625
denny5625's Avatar
Dumb question of the day!
I'm new to the 4 x 4 scene although I own a couple of 1972 4 x 4 Blazers. I just bought a rolling chassis with a 8" lift and 3/4 ton running gear. I don't like the looks of the different offset from the front end and rear end. My question is there any front (what do you call it?) axle that is the same width as the rear that I could put on it that would bolt on? Thanks for any help.
66 el Camino
70 1/2 RS Z-28
71 C10 2wd
72 2 wd Blazer
(2) 72 4 x 4 Blazers
88 24' Mirage 70 mph+
08 Harley Night Train
08 Silverado 4d 4 x 4
denny5625 is offline   Reply With Quote
Old 10-10-2011, 10:40 PM   #2
ryanroo
ryanroo's Avatar
Re: Dumb question of the day!
all of the front axles that are easy to find and bolt in will be the same width. if you can find a 3/4 ton van 14 bolt it will be wider than the current rear. they are 70 inches wms-wms. that is actually half an inch wider than the front but that wont be as noticable as the the 2 inch difference that it has now.
they are not a "bolt in" swap. you will have to re-position the spring perches. there will be several other things that may have to be addressed such as the brakes and parking brake and pinion yoke.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 10-10-2011, 11:08 PM   #3
denny5625
denny5625's Avatar
Thanks for the reply. That sucks cuz the rear is an eaton with posi.
66 el Camino
70 1/2 RS Z-28
71 C10 2wd
72 2 wd Blazer
Old 10-10-2011, 11:52 PM   #4
ryanroo
ryanroo's Avatar
while not my favorite option, there are some well made wheel spacers on the market that you could use to get the rear out an inch on each side. alot less hassle and likely less costly.
ryan
72 K20 12v build
Old 10-11-2011, 10:53 AM   #5
jaros44sr
jaros44sr's Avatar
Or you could do rear wheels with a deeper offset, and front wheels too
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
